Starting Issue
Old Sep 10, 2021 | 04:01 PM
BigRiig's Avatar
BigRiig
Starting Issue
I have a 97 PSD and had a no start issue this morning. Truck has been starting regularly but has had a few "slow crank" days when I let it sit too long between drives (4-5 days). Batteries are about 2 years old and should be good and I am pretty sure the alternator is good as well (although I haven't had either tested yet). The dash lights come on but VERY dim. There is a ticking noise that seems to be coming from the glow plug solenoid and the "Wait to Start" light does not come on. When I try to crank, all the lights go out and nothing happens. I charged both batteries and they are showing full. Battery terminals are clean and tight on both ends. I was planning to pull the battery and alternator to have them tested but it just doesn't seem like either of those are the issue. I have read about the starters going out on these and wondering if that could be the issue? Any ideas?
Also the glow plugs, wiring harness and solenoid have all been replaced recently. I have never replaced the alternator or starter in the 8 years I have owned the truck. Previous owner replaced the alternator right before I bought it. No indication that is was on it's way out.
Old Sep 10, 2021 | 04:35 PM
96 OBS's Avatar
96 OBS
New batteries. These trucks need a lot of voltage to start. Disconnect them and test them separately
Old Sep 10, 2021 | 06:08 PM
BigRiig's Avatar
BigRiig
I was thinking I would get them tested tomorrow. Right now I have a trickle charger on them but they seem to be fully charged.
Old Sep 10, 2021 | 06:22 PM
96 OBS's Avatar
96 OBS
The main thing is they need to be able to pull the load of the starter and the engine. Have them load tested. They can show 12 volts any time until you put a load on them and they’ll drop to slim to nothing
Old Sep 10, 2021 | 06:24 PM
Hit Man X's Avatar
Hit Man X
Well, you could have the starter freshened up if got good shop in town. Or do the 7.3 SD starter that a lot of guys do. Pull the VR on the alternator, I prefer to toss new brushes on a Motorcraft VR.
Clean all terminals real well. @knottyrope has a great thread on voltage drop and such. Learn it. Know it. Live it.
Remember, starter grounds to trans so clean there and alt grounds to bracket.
Old Sep 10, 2021 | 06:30 PM
BigRiig's Avatar
BigRiig
All good info. It is just weird that it started all of the sudden. Usually with batteries you have a slow death but there hasn't been any indication of that. The starter definitely does not crank as fast as other 7.3s I have heard but thought that was just due to age.
Old Sep 10, 2021 | 06:40 PM
Hit Man X's Avatar
Hit Man X
The Braunschweiger looking early starter just has less *** to spin over the engine than the SD 7.3 unit or the big hoss Denso.
You may want to do an amp draw test and see if you have some previous hacker wiring somewhere to deal with too.
Old Sep 10, 2021 | 06:49 PM
96 OBS's Avatar
96 OBS
Agree with the superduty starter. Great improvement. I always wanted to do the 6.7 conversation just for fun
Old Sep 10, 2021 | 06:50 PM
Hit Man X's Avatar
Hit Man X
Step up to my league and go for the Denso!
Old Sep 12, 2021 | 10:26 AM
wkf94025's Avatar
wkf94025
Love it. Thanks.
Old Sep 13, 2021 | 11:22 AM
BigRiig's Avatar
BigRiig
***UPDATE***
Turns out the culprit was the battery cable. Found a bit of corrosion on one of the terminals. Went down to Napa auto parts since they had the upgraded replacement cable in stock for $140+government theft. Installed and now the truck cranks and starts faster than I ever remember. Cut into the old one and found a decent amount of corrosion inside the cable itself. I remember an old mechanic friend of mine telling me years ago that if there is corrosion on the terminals, then there is already corrosion inside the cable. I will say that the cable is a bit of a bear to replace but well worth it. Even if your truck doesn't seem to have issues it might not be a bad investment if the cable has never been changed.
Old Sep 13, 2021 | 03:22 PM
427 fordman's Avatar
427 fordman
Glad you got it, but for that price you could probably have put all new cables on with military style ends.
Old Sep 13, 2021 | 03:26 PM
BigRiig's Avatar
BigRiig
The nice thing was this was actually the less expensive route especially considering the current price of 2ga wire in my area. Additionally, the cable is all precut and shaped since this isn't really an easy replacement. I have seen military style battery posts but not sure of the benefits?
Old Sep 13, 2021 | 07:17 PM
427 fordman
Don't get me wrong, the factory one is a good piece. I just really like the military ones. Wires not that bad here. At least welding cable, which I use. Just bought over 40 feet for 140 bucks.
6.0L
Jan 26, 2020 10:34 AM
dda140
Nov 25, 2014 09:54 AM
countryboy8085
19
Dec 4, 2012 11:00 PM
worm0479
Jul 30, 2012 01:59 PM
WilmsD
Jul 27, 2011 08:16 AM
