Electronic ignition
Old Sep 10, 2021 | 03:05 PM
ChrisCCC's Avatar
ChrisCCC
Electronic ignition
Converting the 70 F100 over to Electronic should be easy as buying a distributor and module for a 74 from Rock Auto.
Why mess with Pertronix when getting the factory type electronic ignition would be cheaper?
Am I missing something here?
Old Sep 10, 2021 | 04:21 PM
RichS2659's Avatar
RichS2659
A Pertronix is less work if your present distributor is still in good shape. Won't have to remove it, and is almost plug and play. You can easily convert back to points if need be. The Duraspark requires more wiring to do it.
Old Sep 10, 2021 | 06:29 PM
lilorbie's Avatar
lilorbie
I've used Pertronix in my 74 VW Bug and in my 67 Ford Mustang using the stock dist. in both cars. It's a very easy swap to do and looks like it's stock.
Old Sep 10, 2021 | 08:07 PM
ChrisCCC's Avatar
ChrisCCC
OK so the Petronix is more for simplicity. I know the Duraspark is a pretty hot distributor that can handle some decent HP.
I was just wondering what the limits of the Petronix was compared to the Ford Duraspark.
Old Sep 13, 2021 | 07:50 PM
JEFFFAFA's Avatar
JEFFFAFA
With the Duraspark you will also need the correct coil. Pertronix has different set ups. With or without their hotter coil.
denny7170
Nov 16, 2016 08:20 AM
greentruck72
Feb 23, 2015 08:10 AM
raven3
Jul 22, 2014 09:45 AM
Holiver31
Mar 9, 2011 07:10 AM
bamaf150
16
Apr 30, 2010 11:56 AM
