electronic ignition
Old Feb 22, 2015 | 05:19 PM
greentruck72's Avatar
greentruck72
electronic ignition
okay this maybe a stupid question but have any of you ever heard of direct wiring the duraspark distributor to your coil for a cheap electric ignition, if so any advise or warnings against, the wires on the distributor are purpleish-brown orange and black?
Old Feb 22, 2015 | 06:46 PM
mikeo0o0o0's Avatar
mikeo0o0o0
I don't really get what you're trying to do. The Duraspark Ignition is already electronic. Wiring the distributor directly to the coil won't work, you won't get any spark.
Old Feb 22, 2015 | 06:58 PM
HIO Silver's Avatar
HIO Silver
Convert to HEI:
How To Convert A Ford Or Chrysler Ignition To GM HEI - Car Craft
Old Feb 22, 2015 | 10:42 PM
bkaul's Avatar
bkaul
I'm with Mike: Duraspark is an electronic ignition package, and with any electronic ignition package, you need a "brain" - in this case, it's mounted external to the distributor. You could swap to a non-electronic, points-style distributor if you really wanted to (but why?) ...
As for Duraspark vs HEI ... If you go with a quality (OEM/Motorcraft) ignition module, Duraspark is great. No reason to switch from the original. Aftermarket modules are of questionable quality, though ...
Old Feb 23, 2015 | 08:10 AM
greentruck72
i've heard of people doing it with 90's 351 distributors, putting them in old engines so i was wondering if you could direct wire the duraspark.
raven3
Jul 22, 2014 09:45 AM
SVTDriver97
Feb 20, 2014 12:01 PM
73FordF100
Sep 15, 2009 03:42 PM
LARIAT 85
Nov 16, 2006 06:30 AM
f100guy
Oct 5, 2003 12:21 PM
