Rims/Tires
Old Sep 10, 2021 | 11:54 AM
rhino_160's Avatar
rhino_160
Rims/Tires
Needing some assistance:
My new 22' F350 SRW Platinum should be arriving at the dealer soon and I am ordering the rims/tires.
I am going with 20" Fuel Siege with 35"X12.5" KO2 tires.
The "look" I want is similar to factory so NOT wanting them to stick out wide.
The dealer is recommending 20x9 rims with those tires to achieve a similar look as far as how far they stick out.
Does this sound correct before I order? If you have a similar setup, please provide a pic. Thanks in advance.
Will also have the FX4 with Level-Up added in the front.
Old Sep 10, 2021 | 12:07 PM
RidgwaySD's Avatar
RidgwaySD
It isn't so much the dimensions of those wheels that make them stick out or not, it is the offset/backspacing you need to concern yourself with. If you do not want them sticking way out looking stupid and throwing junk down the side of your truck, get the +20mm offset offered in that wheel, not the 0 offset which will stick out another ~3/4 inch. Factory wheels are +44mm offset so these will stick out some, approximately 2-2.5 inches further than stock with those wheels and tires.
Old Sep 10, 2021 | 03:38 PM
rhino_160's Avatar
rhino_160
Thank you lots
Old Nov 3, 2021 | 11:08 AM
alliz1986's Avatar
alliz1986
did you end up getting these put on?? 😀
Old Nov 3, 2021 | 11:16 AM
jfcody3962's Avatar
jfcody3962
let's see a pic please, interested in the same wheels
Old Nov 3, 2021 | 11:33 AM
rhino_160's Avatar
rhino_160
sure did!
Old Nov 3, 2021 | 11:43 AM
shaneinga's Avatar
shaneinga
Custom Offsets is a great website to look to see how a set of wheels and tires will look on your truck. You can search by truck year, lift size, wheel and tire combo, etc.
2021 Ford F-250 Super Duty with Leveling Kit and 20x9 on 35s | Custom Offsets (customwheeloffset.com)
Old Nov 3, 2021 | 12:07 PM
alliz1986's Avatar
alliz1986
sure did!
looks great!
Perickson
Jul 16, 2018 10:13 AM
officer131
Feb 8, 2008 06:45 AM
benford
Sep 20, 2001 12:37 AM
