help with carb spacer
Old Sep 9, 2021 | 07:01 AM
fl7379's Avatar
fl7379
Hey guys,first I want to tell everybody how much I appreciate this forum.
I have a carb spacer on my 73 f100 302 that is very close to burning through.
The spacer number is D5UE 9AB89 AB. does not have egr valve on back.
Trying to locate a replacement.thanks
Old Sep 9, 2021 | 08:53 AM
5851a's Avatar
5851a
I can't help you with a number as it was many years ago, same problem so went to Ford dealer and the replacement was made of cast iron.
Old Sep 9, 2021 | 09:18 AM
mwoj's Avatar
mwoj
D5 = 1975 I think. So either it should be D3 or that one is swapped in. Don’t quote me on that though.
Old Sep 9, 2021 | 11:23 AM
fl7379's Avatar
fl7379
thanks guys,the plate is probably not original but the truck ran really good then it started having idle issues like a vacuum leak.It was a leaking gasket.
I hope to find a plate, I wish mr numberdummy or somebody could search obsolete parts. I have not had much luck. Thanks.
Old Sep 9, 2021 | 01:13 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Ask/PM mikeo0o0o0 to do it, he has the same parts searching skills and ability as ND. And is a super nice guy to boot.
https://www.ford-trucks.com/forums/member.php?u=508587
Old Sep 10, 2021 | 10:15 AM
jackietreehorn's Avatar
jackietreehorn
I can grab you one at the boneyard if needed. Let me know sooner than later.
Old Sep 10, 2021 | 11:21 AM
fl7379's Avatar
fl7379
That would be great, I have not found one with the egr bulge on passenger side without
the valve on back. Just let me know. I sent a message but not sure if it was in the right place. Thank you
Old Sep 10, 2021 | 11:34 AM
somethingclever's Avatar
somethingclever
It took 40 yrs for that unit to deteriorate 50% of the wall thickness....i would reinstall and enjoy.
Old Sep 10, 2021 | 11:41 AM
fl7379's Avatar
fl7379
yeah it is actually worse than it looks in the picture. It's chiseled out to really thin just above mounting surface which is thin also.
hard to see it in picture. Thanks
Old Sep 11, 2021 | 11:11 AM
5851a's Avatar
5851a
If worse comes to worse you could have it blasted and have someone heliarc some new aluminum in and remachine surfaces. Had to do it on 85 5.0 GT spacer once.
Old Sep 11, 2021 | 01:02 PM
fl7379's Avatar
fl7379
That's a good idea, this type is tough to find. I located one that was solid on bottom no egr hole. But still covers hole in intake Not sure
how that would effect carb.but if jackietreehorn finds one I will purchase it anyway. Thanks
Old Oct 10, 2021 | 03:05 PM
jackietreehorn
Phil Humber
20
Mar 7, 2022 10:54 AM
FSCboss
May 17, 2020 12:31 PM
eric8
18
Jun 2, 2019 01:20 PM
joncaudill
Mar 2, 2004 04:49 PM
