Sponsored by: Auxito
4x4
Old Nov 2, 2003 | 07:54 AM
00sc4x4's Avatar
00sc4x4
Question 4x4
Just bought a 2000 ext cab 4x4 f 150 and have never owned a 4x4 without a shifter on the floor. So how does the dial type shifter work.
Old Nov 2, 2003 | 10:30 AM
B_7700_4X4's Avatar
B_7700_4X4
You can shift from 2H to 4H at any speed up to 55mph unless the outside temperature is below 0C or 32F. In that case you should be traveling below 45mph or slower in my opinion before shifting. In order to shift from 4H to 4L, you should be stopped with the transmision in neutral, and your foot on the brake. Use the same procedure to shift out of 4L. I hope this helps.
Old Nov 2, 2003 | 10:36 AM
Racerguy's Avatar
Racerguy
Hi 00sc4x4 and welcome to the forum
The (as my friend calls them) "heater control" 4x4's seem to work pretty well without many problems. It's nice being able to just turn the **** and have it go into 4x4.
Some people say that the manual shifters are much more reliable but they have some electronic parts working in the transfer case and to lock in the front axle too so i dont think there is much difference.
Old Nov 2, 2003 | 10:14 PM
aldridgec's Avatar
aldridgec
I just wish there was a neutral position. Oh, and while I'm at it, a 3 on the trans shifter would be nice too.
Old Nov 2, 2003 | 11:15 PM
LxMan1's Avatar
LxMan1
You don't like all of the lazy man's creature comforts on your truck? Twista4x4 and pusha da OD off?
I am spoiled, but I know that over the years, all of these fancy switches and buttons are gonna die on me. But for now, these rank right up there with the TV remote control!!
Jimmy
Old Nov 3, 2003 | 12:46 PM
umdstang's Avatar
umdstang
aldridgec
what is the neutral on the transfer case good for anyways. I know it disengages the tranny to the transfercase.
Any usefull purpose for it??
Just curious b/c i have a neutral position on my floor shifter.
Old Nov 3, 2003 | 01:00 PM
LxMan1's Avatar
LxMan1
It might be good for towing you out of a mud hole if your engine was dead.
Or you can forget you have it in neutral and it will roll away on ya.
Jimmy
Old Nov 3, 2003 | 01:04 PM
umdstang's Avatar
umdstang
Ok i never thought of it that way.
I hope it doesnt role away on me, i like this truck and i hope it doesnt want to run away from me
Brian
Old Nov 3, 2003 | 05:07 PM
aldridgec's Avatar
aldridgec
Neutral: Easy flat towing, or towing on a wheel lift. You really shouldn't tow a 4x4 on a wheel lift by the front. Towing by the rear is better, but still not great, especially if you don't have a center axle disconnect. Have I ever used it, once when I was towing a blazer on a dolly. But that once made it worth not having to take the driveshaft out. Besides, Chevy has it and I don't want chevy to have something I don't! Even if I never use it.
The button dislike, no. But I think it would be much easier to select 3rd gear if it was on the shift selector. The way it is now, its a two step process, put truck in gear and turn off O/D. Where a selector would be a 1 step, put truck in 3 process. You also have to remember to turn off O/D every time you turn the key off (if you are doing it for towing reasons). So in reality the lazy button is more work
Old Nov 3, 2003 | 05:50 PM
umdstang's Avatar
umdstang
Ok that is some good info.
About the O/d button i think that the operation should be reversed. When ever you start up the truck the overdrive should be off. and when you want to, put the overdrive on.
My 2 cents.
P.S. i have to agree with you on the chevy thing
Old Nov 3, 2003 | 06:56 PM
aldridgec's Avatar
aldridgec
Yeah, except that 99.9% of the time I would want it on.
schoo
May 15, 2013 06:55 AM
TrippingCobras
Jun 28, 2012 09:37 PM
thepossumface
May 9, 2011 03:51 PM
fishpimp
Jan 1, 2010 06:16 PM
