Sponsored by: Real Truck
Ujoint question
Old Sep 7, 2021 | 07:11 PM
K5BEAST's Avatar
K5BEAST
Ujoint question
99 f250 super duty. Rear shaft, rear joint. Felt like i had a bad u joint the other day so i crawled under and looked. It appeared that the rear joint was bad as there was slop. I pulled the shaft and the joint was fine. Turns out that the distance between the 2 tabs that locate the joint measures 3.695 compared to the 3.625 of the joint. Is this normal? Seems like a lot of lateral movement to be. Any fixes short of replacing the pinion? I thought about adding a .030 shim inside each of the two caps but not sure how well that would hold up.
Old Sep 8, 2021 | 03:44 AM
Just Strokin's Avatar
Just Strokin
Maybe someone replaced the u joint with wrong one? I would take my calipers and go to local parts store and have them pull one you can the width and compare it to yours. It is i the wide width, I would replace the u joint.
Old Sep 8, 2021 | 09:03 AM
99powerstrokedF250's Avatar
99powerstrokedF250
Definitely sounds like someone used the wrong joint when it was replaced previously. It was either done by a shadetree mechanic or a shop that didn't know what they were doing.
Old Sep 8, 2021 | 09:51 PM
mark a.'s Avatar
mark a.
It's obvious it's a 1350 U joint. I would suspect a U joint failed at one time and wore the retainers the .070 difference. Get a new yoke, they aren't much money in todays dollars.
21
Sep 9, 2009 07:06 PM
jstroud08
Mar 14, 2008 08:23 PM
myowneq
May 19, 2005 11:25 PM
kburch
Bronco II
Nov 8, 2001 07:15 PM
