Keyless entry FOB for 1997 Explorer
Old Nov 2, 2003 | 07:45 AM
gkpettigrew's Avatar
gkpettigrew
Question Keyless entry FOB for 1997 Explorer
Hello All,
Can anyone tell me if a Ford (or otherwise) keyless entry FOB will work on a 1997 Explorer? It did not come with one when I purchased it, but I would like to add one of possible. If so, does anyone know how to program it? I didn't find the programming instructions in the owner's manual.
Thanks in advance,
Kevin
Old Nov 2, 2003 | 09:19 AM
Opera House Works's Avatar
Opera House Works
Hmmmmmmm
When I bought my 97 used at auction, it came with a key fob. Never has worked and I don't think it works on cars without the keypad on the door that mine doesn't have. Aftermarket security tied into the door locks is probably the best way to go at this point.
Old Nov 2, 2003 | 04:04 PM
gkpettigrew
Thanks for your help. I'll continue to investagte other options. Mine doesn't have the keeless entry either.
Old Nov 2, 2003 | 04:59 PM
r3830's Avatar
r3830
Could someone share with me the meaning of FOB?
I fitted keyless entry to my '97. The kit was purchased through an electronics store and is compatible with remote access relay. The existing security system in the vehicle also has the ability to trigger the central locking circuit - although there are not many alarm suppliers/installers who are happy about handing out circuit descriptions. Fitting these things does take some time....door panels off, actuators fitted and adjusted to existing hardware - but the whole exercise wasn't difficult. Cost was about $20US, which did include a full wiring harness. (Had to extend wiring on off-side due to length of runs)
Food for thought?
Paul.
Old Nov 3, 2003 | 12:51 PM
96explorereddieb's Avatar
96explorereddieb
For '95-'97 Explorers, remote keyless entry is part of the package. If you have the password keypad above the driver's door handle, then you should have 2 remotes with it. If you don't have the keypad on the doors, then there're no remotes. I would highly recommend some aftermarket ones. You can get a fairly inexpensive security system for $200 installed while you get a better system than stock.
eman588G
Sep 25, 2016 09:18 PM
z28kilr
1997 - 2003 F150
Mar 13, 2016 05:20 PM
twigsV10
13
Sep 28, 2015 10:33 AM
Beerstalker
1997 - 2003 F150
22
Sep 27, 2007 06:00 PM
adelyser
1978 - 1996 Big Bronco
Feb 12, 2002 12:30 PM
