2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Problem with front brakes
Old Sep 6, 2021 | 11:51 AM
TheMilkman00's Avatar
TheMilkman00
2011 Expedition EL 5.4
So, I have gone through a set of brand new pads on the front driver side of this vehicle in 4 months. I tend to think stuck caliper.
I also have another related situation:
For the last 6 months or so, my dashboard is lit up like a Christmas tree with every brake light and message indicating a problem. People have indicated that this is a generic code, and unfortunately Forscan isn't telling me anything else. On the surface B1342-E0 seems to be a bad ABS ECU. In this case I tend to believe it, because as I recall I pulled up the PIDs for each wheel sensor, and I was able to see on/off data for each sensor.
SO!!!!!!!! My question:
Could there be ANYTHING to do with B1342 that would cause one wheel to burn through a set of brakes. I tend to think no, but I wanted to check with you all for your thoughts on all of this before I proceed.
Old Sep 7, 2021 | 10:16 PM
Newnavowner's Avatar
Newnavowner
When you jack it up with that tire off the ground, does it spin freely by hand? Also, does it pull to that side when driving?
Old Sep 8, 2021 | 06:17 AM
Robrrr's Avatar
Robrrr
Trailering
I had similar problem with my 11 Expedition 4x4 xl. Ended up being bad brake hose on drivers side. After replacing all brake hoses problem solved. After all that 4 months later abs module went bad. I've been told this is rare but just my luck. I found a used abs module and pump assembly on the web for less than $200. New was over $1200. It's been over a year now and all good. Good luck.
Corbin P
1983 - 2012 Ranger & B-Series
Jan 23, 2020 11:13 PM
inspector747
Feb 25, 2015 10:44 AM
stevie624
Dec 8, 2012 05:37 PM
nmh2285
Jan 2, 2009 06:39 PM
adelyser
1978 - 1996 Big Bronco
Jan 2, 2002 04:20 PM
