Gas cap help
Old Aug 30, 2021 | 04:42 PM
bigfoot22's Avatar
bigfoot22
Gas cap help
Need some help finding the correct gas cap for my truck. Went to a cruise in and mine got swiped.
1974 Ford F100 aft mounted fuel tank with emissions. I have ordered 2 from Oriellys with same results with vented cap. I need the non- vented cap with the deep cam. I even drove 2 1/2 hours away to Dennis Carpenter to get one and they only had the vented cap. LMC is showing one but I hate to order something then if its not right, having to go thru the trouble of shipping it back. Going to try a couple of J.Y. tomorrow but last time I was there they had crushed the older Fords. Thanks for the help.
Old Aug 30, 2021 | 05:56 PM
tbear853's Avatar
tbear853
Wish I could help ... other than to point out the field of suspects is likely limited.
Old Aug 31, 2021 | 12:37 AM
DB429SCJ's Avatar
DB429SCJ
Maybe this one:https://www.rockauto.com/en/moreinfo...sn=469&jsn=469
Old Aug 31, 2021 | 04:21 AM
bigfoot22's Avatar
bigfoot22
Thanks for the help guys. I ordered one from rock auto and one from LMC. Pics from both show what I need. Hope for the best on the end results.
I will let you know. Thanks again.
Old Aug 31, 2021 | 02:32 PM
HoustonDave's Avatar
HoustonDave
Bought a locking cap from O'Reilly's, at the time did not know whether it was vented or unvented. Sales guy said to just buy a cap with the same number of latching lugs as my original. I did and it has worked fine for over a lustrum (hat tip to John Wayne.) Where you get in trouble is when you replace a vented system cap with an unvented and eventually create a low-pressure 'vacuum' in the tank. I would think if you use a vented cap, your system (even though presumably emissioned, hence vented from the tank to the carbon cannister) you would be OK. Maybe a stray fume or two?
cat-alac
May 7, 2021 09:19 PM
blue04.5
Jan 12, 2014 05:26 PM
shawnyboy
Aug 5, 2010 09:10 PM
fl1a
Bronco II
Apr 4, 2006 11:03 AM
ceetwarrior
13
Jun 1, 2004 05:46 PM
