What did you do to your OBS today?
Old 04-23-2024, 05:32 PM
Soup bean's Avatar
Soup bean
Soup bean is online now
Painted my floor patch panels and areas around my bed bolts with POR 15. Rust-Oleum wasn't holding up in the driver's side floor.
  #647
Old 04-24-2024, 02:08 PM
Soup bean's Avatar
Soup bean
Better picture of the floor from today.
  #648
Old 04-24-2024, 06:40 PM
Edgethis's Avatar
Edgethis
Edgethis is offline
Put a shiny ccv merbob on my engine. Basically a pcv for diesels.
Got to use a new worklight. Super bright and folds up for easy carrying
The following users liked this post:
  #649
Old 04-28-2024, 08:04 PM
Soup bean's Avatar
Soup bean
Washed it.
  #650
Old 05-01-2024, 11:59 AM
WanderingDruid's Avatar
WanderingDruid
WanderingDruid is offline
4th Gear
Talking
I finally got my dash rebuilt and installed back in the truck, just have a little left to do on the interior and then starting on the engine.
This is what I started with.
This is what I put back in Yesterday!
  #651
Old 05-01-2024, 02:25 PM
OBSession05's Avatar
OBSession05
OBSession05 is online now
Very nice work! How hard was the install?
  #652
Old 05-01-2024, 02:31 PM
WanderingDruid
4th Gear
The install was not to bad, it helps a lot to have two sets of hands though. It was much harder fixing the dash and getting it painted than it was putting it back in.
  #653
Old 05-01-2024, 09:24 PM
OBSession05
Hurried back over to the shop before a storm hits so I could grab the impact I forgot outside
  #654
Old 05-02-2024, 07:04 AM
WanderingDruid
4th Gear
Nice, I spent a lot of time rubbing the green paint off of my dash gauges and putting in blue LEDs. I will try and get a picture of that soon, working on the motor now that I got the dash in. The person that had it before me tried deleting the smog system and really went overboard with the delete button. He had the fuel purge solenoid removed and had the line for it plugged into the coolant outlet on the throttle body, the bottom throttle body coolant nipple was sealed off with a hose and a wooden dowel. And the main vacuum hose for the cruise control was plugged onto the throttle body nipple where the fuel purge solenoid was supposed to go. I have a lot of work ahead of me lol.
  #655
Old 05-02-2024, 09:11 AM
tcanthonyii's Avatar
tcanthonyii
tcanthonyii is offline
Attempted to find the AC leak in my 96. Not sure if I made it better or worse. Going to pick up a sniffer today at lunch and charge the thing tonight and see what I can find. It at least has aa few new O-rings in it now and shrader valves. Bleeds down to -10 pretty quick and held a -5 all night. got a feeling it's either the high pressure side hose or the compressor but even the dye I put in it last year isn't helping things.
  #656
Old 05-02-2024, 10:35 AM
Duke5A's Avatar
Duke5A
Duke5A is offline
Trailering
Swapped a factory tach cluster (kept original speedometer) and add a gauge pod under the dash. Used 65 lumen LED bulbs. I like how it came out.
The following 2 users liked this post by Duke5A:
  #657
Old 05-07-2024, 10:54 AM
Soup bean's Avatar
Soup bean
Checked the transmission fluid in my M5ODR2. It was a pint low. I like to keep an eye on it.
This is a good tool for adding fluid.
  #658
Old 05-08-2024, 12:26 PM
Duke5A's Avatar
Duke5A
Duke5A is offline
Trailering
Popped the passenger rear wheel off and gave my new needle scaler a try on the section of frame rail. Probably hard to tell from the photo, but it knocked the scale completely off. Took about 30 minutes for the area shown. When the bed comes off in a couple weeks and I strip down the rear of the truck I'll do the entire frame. Pretty damn happy with it.
  #659
Old 05-08-2024, 07:31 PM
samuel4wolfpack's Avatar
samuel4wolfpack
samuel4wolfpack is offline
New to me 1996 F250 4x4, new tires today
I got this truck on May 4, 2024 from a private party, 5.8 with ZF5 and 3.55 limited slip (need to verify axle tag) with 165,000 miles. The tires that came with this truck are Toyo A/T, I could see the top of the head for the penny while doing the tread test. I am at Discount Tire and having them install new Pathfinder A/T tires today.
Since on my 1991 F250 I had bought the replacement certificates for the Pathfinder HSR tires but I didn't have any tire issues in the 14k miles I drove (before my truck was a total loss), I decided not to get the replacement certificates for these new tires, even though I have the option to add them later, I believe.
An overall view of passenger side, of the 1996 F250 4x4 that I bought on 05/04/24.
Toyo A/T that originally came with the truck when I bought it the other day.
The following 3 users liked this post by samuel4wolfpack:
  #660
Old 05-10-2024, 06:02 PM
matkinson13's Avatar
matkinson13
matkinson13 is offline
Finally got around to (badly) cutting a plexiglass replacement window for the camper shell I got a few months ago. Pushed the shell forward on the bed so it sits better now, and started wiring up the shell's third brake light. Plan is to also wire the shell for power.
Quick Reply: What did you do to your OBS today?
