Truck too a crap!
Old Aug 26, 2021 | 08:48 PM
Listor's Avatar
Listor
Truck too a crap!
Just driving along hit a little bump and the truck died ? started right back up a couple of times, then didn't , had to get towed home , charging batteries now!
Thinking i have a bad ground somewhere , help me find them asap!
I am actually going out of town for a few days, so will have to deal with this on sunday as i need the truck for work on monday LOL
Old Aug 26, 2021 | 08:49 PM
RacinJasonWV's Avatar
RacinJasonWV
Do you have the chip firmly secured to the PCM?
Old Aug 26, 2021 | 09:02 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Check the easy stuff first...
42 pin connector over the valve cover, battery terminals, if you have a 2002+ there is a positive power block under the air box.
Fuse for the PCM tight?
Fuel pressure?
Oil level?
Sensor connectors secure?
Etc...
I just pulled the ground locations for another FTE'r here: https://www.ford-trucks.com/forums/1...l#post20032631
Old Aug 26, 2021 | 09:20 PM
Colorado350's Avatar
Colorado350
I had the same thing happen getting off the interstate. I happened to catch that the WTS light wasn’t coming on…I put a new fuse in and was back on the road. During the drive it occurred to me that I was able to pull the fuse without a puller. Turned out the fuse was loose in the socket. Just something to consider besides the obvious things….
Old Aug 26, 2021 | 10:31 PM
Listor's Avatar
Listor
Fuel pressure?
Oil level?
Etc...
I agree the easy stuff 1st , I am sure it’s something simple just in the way it happened I did push the hydra to check for play felt none, wife and I heading out to Denver , her 1st outing since getting her knee replaced, so I will deal with it when I get back don’t want to put a damper on her need to get out!
Old Aug 27, 2021 | 07:29 AM
Sous's Avatar
Sous
FTE Emeritus
That is a solid and well thought-out plan sir. Good to hear your wife seems to be doing well after her recent procedure. The truck is just a truck, the relationship and your time with your wife is irreplaceable.
About 2 years ago I had a symptom where the Hydra chip was securely installed for a few years and then turned out to be just loose enough during a "tooth shattering" pot hole while towing heavy east of Knoxville TN on our way home from the Great Smoky Mountains NP. I reinforced the chip with some semi-rigid foam and more securely fastened VHB tape. I used the old method to install the chip which was to cut a decent sized hole in the back of the black case.
If that didn't work, I was going to order a new case from RiffRaff and simply replace the cut one. No big deal as it has been holding well for a while now and about 7,000 miles of traveling.
Keep us updated, but more importantly, have a good, safe and memorable trip!
Old Aug 27, 2021 | 04:05 PM
jstihl's Avatar
jstihl
Correct me if I'm wrong here guys but I thought I remembered a thread a while back that had the same symptoms as listor and it was a loose tinnerman nut on the IPR? I think the fella in the other thread said it happened when he went over railroad tracks or a pot hole. Worth checking anyways
Old Aug 27, 2021 | 06:44 PM
Listor's Avatar
Listor
I did check the ipr last night , but i was a little rushed heading out to dinner ect, i will go though everything on sunday, or monday if we get back to late
I do have a new unit i may change out
Old Aug 27, 2021 | 07:25 PM
jstihl's Avatar
jstihl
You probably are already aware of this but a 1/2-20 unf skinny nut is much more sturdy than the "tin" nut on the ipr if your interested in changing it out. .25 cents for a peice of mind is well worth it! Hope it's as easy as the ipr nut for ya!
Old Aug 27, 2021 | 08:49 PM
Listor's Avatar
Listor
That's not a bad idea while i have the new one out
Old Aug 28, 2021 | 08:27 AM
WNYPSDguy's Avatar
WNYPSDguy
Check the fuel safety switch reset in the passenger footwell area too. I didn’t know about that until I started tearing Into the truck to do some noise proofing.
Old Aug 28, 2021 | 08:30 AM
FordTruckNoob's Avatar
FordTruckNoob
Get a jam nut. A full height nut won't engage all the threads on the end of the IPR anyway. The ultimate is a locking jam nut.
Old Aug 29, 2021 | 06:10 PM
Listor's Avatar
Listor
I will look into it, just got home and tested the batteries, one is not holding under a draw so I will replace them both
Old Aug 30, 2021 | 09:13 AM
Listor's Avatar
Listor
alright got a set of AGM's 84 coming to my local Napa , going to go out and poke around till they get here,. I notice i have a large oil spot under there too!
Old Aug 30, 2021 | 01:17 PM
Listor's Avatar
Listor
Ok new batteries are in truck started right up, after about a minute is died like i turned off the key,
checked codes once that happened found it's not reading the pcm?
Ipr is good, tinnerman nut is in place and tight, icp looks good pulled the connector all is clean and dry
what i did notice is that as i was moving wires arounf, the pcm harness seems to have an issue, of course i have had this thing in and out half a dozen times over the past few months, could i have bent a pin, possibly a burnt connection? I will find out, stay tuned for my favorite part of HOLD MY BEER WHILE I HIT THE HIGH DIVE!
