vent window replacement
Old Aug 26, 2021 | 08:09 PM
cal401's Avatar
cal401
Question vent window replacement
I'm going to replace vent windows on my '60 F-100. I did some searches here but didn't find much in the way of tips on how to remove the old glass from the frame and install the new glass.
@randowe suggests using an innertube to make the rubber strip to set the glass into the frame: link
Mac's has Window Glass Installation Tape for $9.99: link
LMC (where I'm buying the new windows) doesn't seem to carry it.
It looks like I could use RTV silicon to bed the new glass into the frame instead.
Any tips/suggestions would be welcome. I'm perfectly happy to take the old frames/glass to a glass shop and have them put the new glass in, but I'm not sure it that's something that they do on a regular enough basis to be a good idea. If you've had a glass shop do this, what did they charge?
Thanks!
Cal
Old Aug 27, 2021 | 06:24 AM
manglass's Avatar
manglass
I would say try to find an old glass shop that's been in business a while or someone who handles classic cars.
The times I've seen it done, it involved a lot of silicone lube and a rubber mallet. Certainly not for the timid.
Lou Manglass
Old Aug 27, 2021 | 07:58 PM
spurredon's Avatar
spurredon
I used thin cork for mine and followed up with RTV to fill the voids as the cork could have been a little wider. You could just buy this stuff. 1948-1989 Ford Truck Window Glass Installation Tape (ecklers.com)
If I remember right it took a little effort to get the old glass out of the frame. There are several threads on here about this if you look for them.
4EyedTurd
May 1, 2019 03:04 PM
Gotanoldtruck
Mar 19, 2014 05:22 PM
f100today
Dec 25, 2013 08:35 PM
littlecobra1977
Nov 7, 2011 08:54 PM
packrat56
May 15, 2004 11:16 AM
