1985 f150 302 efi code 18
Old Aug 26, 2021 | 08:08 PM
jacob10miller's Avatar
jacob10miller
Truck has a long start, surging idle, hesitation, and stalls sometimes, hesitation seems to go away after warming up but still stalls every now and then. I pulled a code 18 which says bad icm or grounded spout. I changed the icm but same thing. I noticed that the distributor won't turn by hand, you have to tap it with a hammer to spin it, not sure if that has to do with anything but would greatly appreciate some help!
Old Aug 26, 2021 | 08:13 PM
jacob10miller
I believe truck also has a miss, I've also changed spark plugs fuel, pump fuel lines and fuel filter. Im sure its not a fuel problem.
Old Aug 26, 2021 | 09:13 PM
jacob10miller
Truck is now pulling code 14, camshaft sensor.
Old Aug 27, 2021 | 07:26 PM
Franklin2's Avatar
Franklin2
For the code 18, check to make sure your spout connector is in place and plugged in.
For the code 14, that is a missing PIP signal to the computer. Your truck does not have a crankshaft sensor. The guy in the book goes through a long drawn out process to check the PIP wire and some grounds. If all those check out, then he says it has to be the ECM. Funny, you just changed the ECM. Now you have a code you did not have before. I would put the old ECM back in place and see if the code 14 goes away. If it does lesson learned; New or rebuilt parts are not necessarily good parts.
Old Aug 29, 2021 | 05:13 PM
jacob10miller
Ok changed the distributor and the mis is gone but it still has a long start and hesitation when cold but once it warms up that goes away, is this normal?
Old Aug 29, 2021 | 05:21 PM
Franklin2's Avatar
Franklin2
You may have a leak in the fuel system somewhere. It could be a leaky injector, a leaky fuel regulator or a leaky check valve in the fuel pump. First thing to do is determine if that is the problem. Something you could try when starting cold is to turn the key on so the pump primes, and then turn the key off and then turn it on again till the pump primes again. Do this 3 or 4 times before cranking, and then crank it over and see if the start time is shorter. If it is, this may be a hint that it's not holding fuel pressure in the system. You then need to verify this is really the long cranking problem by getting a fuel pressure gauge and check the pressure to see if it leaks down. Major problem with this on a early truck like yours; Some of the early fuel injected trucks did not have a fuel pressure test port. Before buying a fuel pressure tester look on the fuel rail on top of the engine and see if you have a test port, which will look like a tire valve.
Old Aug 29, 2021 | 07:20 PM
jacob10miller
I've tried this and priming the pump doe's not help the start time or the hesitation.
Old Aug 29, 2021 | 07:29 PM
jacob10miller
Also I noticed that when you first start up the truck the rpms dip down then raise back up to normal when cold.
Old Aug 30, 2021 | 11:24 AM
Max Capacity's Avatar
Max Capacity
Do these trucks have an IAC (idle air control) ? I know that come become clogged with carbon on some cars.
After some searching I found they do,
https://www.google.com/search?q=9f71...hrome&ie=UTF-8
https://www.garysgaragemahal.com/198...-302-wefi.html
Old Aug 30, 2021 | 11:30 AM
jacob10miller
Yes it does, that's what I was thinking but I wasn't sure if the iac would cause the hesitation, I will clean it when im home and see.
Old Aug 30, 2021 | 05:53 PM
Max Capacity
The intake air system looks pretty simple from the picture from Gary's site.
You could have a fuel pressure issue too, as mentioned above. Dave F is pretty good with these issues.
Old Aug 31, 2021 | 05:35 PM
jacob10miller
Cleaned Iac, still the same thing truck acts like it's not getting gas when cold. Once it warms up it runs great.
Old Aug 31, 2021 | 05:52 PM
jacob10miller
I have already checked the fpr and there are no fuel leaks.
Old Sep 1, 2021 | 07:32 AM
Franklin2's Avatar
Franklin2
There is no way to check for the leak I am talking about without putting a pressure gauge on it. With the system off and pressure on it, it should hold pressure for a long long time. If there is a leaky injector or two, they will let gas dribble into the engine when it's off and it will lose pressure quickly. If the fuel pressure regulator is leaking internally back down the return line, you will lose pressure. If the check valve in the pump is leaking, you will lose pressure. Low pressure when starting causes long crank times.
Rembrant
26
Feb 3, 2019 03:26 AM
mhofmann86
Sep 22, 2015 03:45 AM
bpjpmo
Sep 16, 2006 11:22 PM
blacksmithtech
29
Jul 25, 2005 05:54 PM
fordman102
Jul 27, 2003 04:54 PM
