Front end torque specs
Old Aug 22, 2021 | 03:50 PM
Rob89's Avatar
Rob89
My level components are ordered and with any luck from the shipping gods, I’ll be leveling my truck next weekend.
Looking to see if anyone has torque specs for:
upper shock mount
lower shock mount
Castle nut on top of the caster shims
sway bar frame mounts
thanks!
Old Aug 22, 2021 | 10:01 PM
Sonny Crockett's Avatar
Sonny Crockett
Don't the specs. depend on the lift you buy?
Old Aug 23, 2021 | 04:52 AM
Rob89's Avatar
Rob89
1.5” PMF spacers, SPC caster cams and Bilstein 5100 shocks.
Old Aug 23, 2021 | 07:04 AM
Rob89's Avatar
Rob89
Here’s what I think I know:
Top shock mount: 55 ft lbs
bottom shock mount: 115 ft lbs
castle nut above caster shim: 75-85 ish ft lbs
spring perch: 150 ft lbs with locktite
sway bar to frame: no idea. Seen everything from 35 ft lbs to 85 ft lbs.
Benny123
Apr 5, 2020 11:24 AM
P4IN COMM4NDO
18
Oct 12, 2016 06:09 PM
Ian123
May 19, 2011 04:41 PM
CobraGT40
Sep 7, 2006 05:18 AM
dynamic
Aug 16, 2005 09:18 PM
