Grounded MAP sensor?
Old Aug 21, 2021 | 03:15 PM
7.3Xcursion's Avatar
7.3Xcursion
Hi all,
Going through electrical in my new to me excursion. When removing the cold side intercooler pipe I noticed that this wires is spliced and connected to a chassis ground. Not sure who did it or when it was done. I asked my dad, who owned the truck before me and bought it new, and he can't remember doing it. It's all corroded and was done pretty poorly. Would this be for a tune? The truck had an EEC tuning module on it, that I think was made by Van Aaken? Would a tune require the map sensor to be grounded? I pulled the chip, just trying to figure out why this hack job is in here.
Old Aug 21, 2021 | 05:54 PM
ESwift's Avatar
ESwift
CNCFAB
I would assume it is a type of method to fool the signal to pcm of boost levels
Old Aug 21, 2021 | 06:02 PM
7.3Xcursion
Supposedly that's what it's for. Looks like another wire I need to fix on this rig.
Old Aug 21, 2021 | 10:26 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
To piggyback on what ESwift said, I believe it was a very rudimentary method of fooling the PCM to see false readings from the MAP sensor.
You may be able to use some DeOxIt to clean up the wire and liquid electrical tape and repair the wire. I believe you can get a new pigtail for the MAP sensor if you want to go that route.
I can post the pinpoint test from the Ford Service Manual if you want to check it for functionality further than what is observed with FORScan, AE or TorquePro.
Easy fix!
Old Aug 21, 2021 | 11:50 PM
7.3Xcursion
Easy fix!
I'll just liquid electrical tape it. I'm going to have to re-wire the entire harness at some point so it's not a huge deal.
Maillemaker
Mar 13, 2026 12:35 PM
jrgarrett
May 8, 2024 12:01 AM
Pablo Chacon
5.0L Coyote
Nov 10, 2020 10:02 AM
mcali2
Apr 1, 2016 11:38 AM
Macrobb
29
Aug 13, 2014 01:16 PM
