Sponsored by: Real Truck
Help with p0112 code? 99 7.3 AT
Old Aug 19, 2021 | 09:39 PM
Sweet Light Crude's Avatar
Sweet Light Crude
1999 7.3 4x4 AT.
Throws p0112 code only. Sensor resistance tests in parameters with multi meter ohms. (Stuck in a/c vents and watched resistance change). Ground side of sensor tests proper. Positive side of sensor gets battery voltage (12.xx) not 5 volt reference voltage. With sensor plugged in voltage across sensor drops into 10.xx volt range. (Which seems to be proper voltage drop) if starting at 5 volts
HighSilver
May 17, 2019 06:08 PM
Matt.gullo
Aug 19, 2016 08:39 PM
danjohnson67
Apr 29, 2009 09:12 AM
sainty333
Dec 19, 2006 09:44 PM
fsds123
1983 - 2012 Ranger & B-Series
Sep 8, 2003 07:15 PM
