throttle position sensor??? p0122
Old Sep 8, 2003 | 05:29 PM
fsds123's Avatar
fsds123
My wife has a 98 ranger and the Check Engine Light came on about a month ago. My wife went to get it inspected last week and it failed due to code p0122- TP sensor circuit low.
I replaced the sensor, reset the ecu by unplugging the battery for 30 minutes. I then drove 30 miles and it came back. Any ideas?
Old Sep 8, 2003 | 06:18 PM
Rockledge's Avatar
Rockledge
Hi fsds123, welcome to FTE!
First you have to make sure it's the same code that you are getting. You don't want to be chasing ghosts.
Ford has this to say about code P0122:
"The TP sensor circuit is monitored by the PCM for a low TP rotation angle (or voltage) input through the comprehensive component monitor (CCM). If during key ON engine OFF or key ON engine running the TP rotation angle (or voltage) changes below a minimum calibrated limit, the test fails."
Posible Causes:
-TP sensor not seated properly
-TP circuit open to PCM
- VREF open to TP sensor
- TP circuit short to GND
- Damaged TP sensor
- Damaged PCM
Hope this helps.
Old Sep 8, 2003 | 07:15 PM
Mike W's Avatar
Mike W
Buy a code reader to save some time running around. I bought a Innova model 3100 last sat at Kragen auto. Was on sale for $99, reg $150.
myblkex
Jan 18, 2017 06:11 PM
5280
Dec 28, 2016 05:17 PM
Farmboypowerstroke
Sep 30, 2015 06:41 AM
plgebbia
22
Jul 12, 2013 10:54 AM
dalesatter
May 24, 2010 07:00 PM
