Steering Wheel Not Straight
Old Aug 19, 2021 | 03:57 PM
scottz99's Avatar
scottz99
Veteran: Navy
I took my F-450 (25k miles) in to the local tire shop for alignment because the outside edge of the front tires were wearing too much. As suspected the toe was off a little. After the alignment, the truck drives fine (maybe a very slight left pull, but that could be the road) but the steering wheel is off center. I watched and the alignment tech did not test drive the truck. I can take it back but would rather save myself the time and miles by doing it myself.
So, the question is, can I center the steering wheel with the adjustment sleeve (photo attached) on the upper tie rod without affecting the toe setting? Looks like I can since the lower tie rod will still be locked in place; but I'm not a front end guy.
The other question is should I be concerned about the very slight pull to the left? If I let go of the wheel, it takes the truck about 5-8 seconds to start crossing the center line. I know, not very scientific, but all I got. I think it is probably ok.
Thanks
Old Aug 19, 2021 | 04:09 PM
4wd6.7L's Avatar
4wd6.7L
Yes you can adjust it yourself without having any affect on toe. It's very easy.
Old Aug 19, 2021 | 04:11 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
The drag link off the steering box arm will be the place to get the wheel centered.
Changing the tie rod will change the toe setting.
Personally, I'd recommend taking it back to the alignment shop, they charged you to do the job and didn't do a complete job for you.
Mark250's Avatar
Mark250
I had the same issue and adjusted it with that collar. Was not able to get that anti-rotating tab in the slot as shown on yours though.
Old Aug 19, 2021 | 04:30 PM
BillyE's Avatar
BillyE
It’s almost certainly rusted up. You can do it but it takes some working back and forth with penetrating oil.
Old Aug 19, 2021 | 04:33 PM
85e150's Avatar
85e150
Take it back.
Old Aug 19, 2021 | 05:03 PM
Mlarv's Avatar
Mlarv
I guess I am old school. I paid for a job to be done and it was not done correct. I bring it back to shop and have them make it right.
Old Aug 19, 2021 | 06:31 PM
scottz99's Avatar
scottz99
Veteran: Navy
Me too, but it's just not worth a 50 mile drive and sitting around their shop for an hour. Besides, would they do it right the second time?
Anyway, I fixed it in about 15 minutes. Thanks all.
Old Aug 19, 2021 | 06:34 PM
scottz99's Avatar
scottz99
Veteran: Navy
Why, was it rusted too bad? I just loosened the nut on the tab and it rotated with the adjuster; with a little tapping from a hammer.
Old Aug 20, 2021 | 05:28 AM
B-ManFX4's Avatar
B-ManFX4
You shouldn't loosen the tab up at all. Loosen the two clamps, spray the whole assembly with silicon lube and use a big pair of channel locks to rotate the sleeve to make the adjustment. The tab keeps the clamps in place while the sleeve rotates within them.
Old Aug 20, 2021 | 08:28 AM
Sonny Crockett's Avatar
Sonny Crockett
My steering wheel is never straight centered. I took truck to the alignment shop twice and the alignment was fine both times. It's probably because of my lift. Yours might be OK too.
Armyrules2
Dec 11, 2017 09:51 PM
traderssd
29
Oct 18, 2016 03:54 PM
traderssd
1978 - 1996 Big Bronco
Jan 16, 2013 01:06 PM
mattd17
2004 - 2008 F150
Jul 1, 2007 03:38 PM
X-Power
May 6, 2007 10:04 PM
