1978 - 1996 Big Bronco
Lift question
Old Nov 1, 2003 | 11:50 AM
Jtanner76's Avatar
Jtanner76
Lift question
I have a 93 ford Bronco, and would like to give it a 6 or 8 inch suspention lift. It's stock right now. Anyone have any advice of which lift to go with, product wise? cheap is good, but quality is great.
Jeremy
71 ford bronco sport
Old Nov 1, 2003 | 02:21 PM
greystreak92's Avatar
greystreak92
Your best bet here is to do a little research. You will get as many recommendations as there are manufacturers of lift systems. Someone has had a good or a bad experience with almost all of them. There are many names thrown around when discussing these products. The best bet is to read and understand as much about them as possible before making the decision.
Some names and addresses you may want to look at:
Superlift
www.superlift.com
Rancho
www.gorancho.com
Rough Country
http://rough.roughcountry.com
Tuff Country
www.tuffcountry.com
BDS
www.bds-suspension.com
Skyjacker
www.skyjacker.com
Explorer Pro Comp
www.explorerprocomp.com
Trailmaster
www.trailmastersuspension.com
On a completely subjective note, I absolutely love the Tuff Country lift that I have. They provide for some additional alignment capabilities that are incorporated into the lift components which can be very helpful when dealing with the TTB front end.
Old Nov 1, 2003 | 03:21 PM
KNZRHOG's Avatar
KNZRHOG
I've lifted my truck 3 times now. If I were to start from scratch again, I'd go with the 8" Skyjacker kit. With 9" of lift I just clear 35x14.5x15 tires on 10" rims. You can see a picture of my truck in my gallery to get an idea.
Old Nov 1, 2003 | 09:24 PM
1991fseries's Avatar
1991fseries
is there any companys that have extended radius arm with there kit
Old Nov 1, 2003 | 10:05 PM
KNZRHOG's Avatar
KNZRHOG
Usually when they list it as a "system" it will include the radius arms and sometimes shocks. The "kit" doesn't usually have either. You'll want to make sure you have all the parts needed to compare prices.
Old Nov 1, 2003 | 10:53 PM
1991fseries
all the kits I have looked at have drop brackets for the raduis arms, not extended ones
Old Nov 1, 2003 | 11:07 PM
KNZRHOG's Avatar
KNZRHOG
Here's a link to the Superlift Superrunner system with the arms and shocks. You can check out Skyjacker on their site too.
http://209.240.4.82/acb/showdetl.cfm...=1504&CATID=12
Old Nov 12, 2003 | 02:30 PM
rlh's Avatar
rlh
All the companies mentioned above by Greystreak92 offer an extended radius arm except Rough Country. Don't no why they don't.
lift_it_higher
Aug 21, 2008 09:24 PM
krave
Apr 16, 2008 02:45 PM
slimbronco
Bronco II
Oct 6, 2004 03:44 PM
351Bronco
16
Dec 26, 2003 03:57 PM
bronco351
Sep 21, 2002 10:09 PM
