add a bigger lift
add a bigger lift
You would be better off selling your 4 and buying a 6. I belive all the front parts such as springs, pittman arm etc would have to be traded anyway. But who knows there might be a cheap way to make a 4 into a 6.I dont think bodylifts look good on broncos I would not reccomend one.
add a bigger lift
What Brand Lift do you have? I know that my Skyjacker lift has holes in the pivot brackets for a 4" and 6" of lift. Would you do the work yourself or would you take it to a shop to have done?
Might be good time to upgrade to things like extended radius arms, if you don't already have them.
I took the cheap way out and threw on a 2" body lift. I wouldn't recommend it.
add a bigger lift
I am going to upgrade my pro-crap 4 inch to a 6 inch also. All I need is new front springs and additional lift for the rear. Also shocks, brake lines, and front sway bar drop brackets. I have already upgraded to extended radius arms and these can be used with the 4 inch lift springs or the 6 inch lift springs. The axle pivot brackets can be moved down one hole and be re-used also.
Your application may be different, but some lifts are easily upgraded.
add a bigger lift
The Body lift was a real PIA to install and it's not really functional other than clearance for tires. Plus it comes with brackets to raise the front bumper but not the back.I'm planning to try and fab up something for the rear. I sure wouldn't want to hit anything with those brackets they supplied for the front bumper. It's a performance Accessories body lift.
Just remember You get what you pay for.;-)
"Top Fuel" Bender
10-23-2010 12:55 AM
