Tranny Shutter?
Old Nov 1, 2003 | 11:27 AM
Code 5 Ford's Avatar
Code 5 Ford
Angry Tranny Shutter?
As I pull away from a stop sign, light,anythig, I get a small 1 second shutter, then it goes away. But returns when I stop and go again. Barely noticed it but I can. Any ideas as the cauce of the problem or is it just normal? Seems to be coming from tranny? I dont know,,,,,,,,,,,,,,2002 F-350 crew cab 7.3 stroker4x4
Old Nov 1, 2003 | 01:53 PM
furball69's Avatar
furball69
not sure what exactly you mean by shutter, but if you mean the truck shakes a bit, it could be the drive shaft or U-joints.
Old Nov 1, 2003 | 02:13 PM
SimCity's Avatar
SimCity
Shutter or Slipping
I have a 00' F250 SDP and I am getting a similiar sound or feeling. When you take off from a stop I feel what seems to be like a slip or torque up. I have asked some buddies and some seem to think that it is dry splines where the drive shaft goes into the transmission or transfer case. (I don't remember which) It was explained to me that when the splines get dry, they bind up and you can feel it.
Old Nov 1, 2003 | 07:53 PM
Code 5 Ford
How do you keep the splines "wet"?
Old Nov 3, 2003 | 07:45 PM
FLASH 13's Avatar
FLASH 13
I GOT THE SAME PROBLEM ON MY2000 F250 PSD WHEN I TOW I GOES AWAY. BUT I HAVE NO IDEA WHAT IS GOING ON
Old Nov 4, 2003 | 05:09 PM
SSN621's Avatar
SSN621
https://www.ford-trucks.com/forums/s...threadid=20042
Here is another thread with some pretty good info.
Old Nov 4, 2003 | 07:53 PM
RRMike's Avatar
RRMike
It's most likely a carrier bearing issue. When you tow you put more weight on the rear end causing less of an angle at the carrier bearing. It might need to be shimmed down some to lessen the angle or replaced.
d4nnyb0y02
Escape & Escape Hybrid
Nov 27, 2011 08:16 AM
motorhead5673
1997 - 2003 F150
Dec 12, 2009 08:54 PM
steven ledwith
Dec 14, 2007 07:11 PM
tonycando
1997 - 2003 F150
Nov 26, 2005 08:30 AM
Firefighter 1406
1997 - 2003 F150
Oct 20, 2004 11:51 PM
