Sponsored by: Real Truck
Ball Joints....
Old Aug 17, 2021 | 09:58 PM
PJWhelan's Avatar
PJWhelan
Ball Joints....
I have a 2002 F-250 5.4L XLT CC 4WD and I want to change the ball joints for starters. Upper and lower, right and left side, I am getting that squeaking on the turns..... The truck has 218,000 and it's been more than 11 years for these Ball joints. While I am at it what other parts in the front suspension would need a second look? I am the original owner and I know the front hubs are well beyond their years. I know I am going to remove the axle and redo the seals. I want to be able to plan this out for a Fall Project. Any thoughts would be helpful..
......And most importantly what brands of Ball Joints would you recommend? Suspension components....sway bar, bushings....
Old Aug 17, 2021 | 11:05 PM
Colorado350's Avatar
Colorado350
Kryptonite ball Joints,
I would also do DL,TRE, etc…
https://kryptoniteproducts.com/produ...per-ball-joint
Old Aug 18, 2021 | 08:11 AM
bajaphile's Avatar
bajaphile
I take it you've seen this writeup?
2004 F250 Ball Joint Replacement
Aside from BJ's, I'd do the axle U-joints and seals. You could do the hub assemblies as well since they'll be off.
Old Aug 21, 2021 | 12:23 AM
reptar0077's Avatar
reptar0077
Good article found this myself as I'm also just about to do this job & would love to follow for more input.
Here is some useful links I've used to purchase some of the parts for this upcoming project.
Thrust washers for your hubs, as I've read this will crack over the years. Might as well replace while your in their.
Amazon Amazon
If needed or lost you can get new Spicer hub washers.
Amazon Amazon
If needed or lost a new snap ring for hubs.
Amazon Amazon
Wheel bearing & hub unit. Read reviews that say you need to pack the needle bearings with grease for the hubs as well as check the hub grease itself as some report way premature failure due to missing/lack/ or grease?
This comes with a new hub seal.
Amazon Amazon
Front axle wheel seal. (Outer/inner? Forgot)
Amazon Amazon
OTC wheel seal installer tool. This sets the seal to the correct height as you can install to shallow or deep without it.
Amazon Amazon
Axle seal (Inner/outer? Forgot)
Amazon Amazon
For ball joints I've read time tested forum threads and went with the MEVOTECH Terrian Tough series.
https://www.rockauto.com/en/catalog/...ll+joint,10070
New front Axle U-Joints went with sealed for life spicer life series coated, due to our road sprays for corrosion protection.
https://www.rockauto.com/en/moreinfo...414853&pt=2392
https://www.rockauto.com/en/catalog/...sal+joint,2392
DO NOT recommend any Moog parts as all my suspension components I've used from them have all failed prematurely.
For suspension I installed some Bilstein 5100's as they have really nice corrosion protection being zinced as well as having a clear coat over that.
Amazon Amazon
You could do some sway bar links while your in their, I'd go with some Mevotech as I've had good luck
with all their parts.
I'd do sealed as they just always seem to last longer.
https://www.rockauto.com/en/catalog/.../+bushing,7580
https://www.rockauto.com/en/moreinfo...414853&pt=7580
EDIT- Add on some DORMAN 917513 hub mounting bolts.
https://www.rockauto.com/en/moreinfo...pt=11542&jsn=7
Need to measure my hub diameter tomorrow to see what size posi lock puller I need to order.
Amazon Amazon
Anyone please add onto this list for anything I'm forgetting? Will update for more links for parts if I am missing something?
IHateCommieCars
Oct 28, 2015 01:10 PM
rfarmery
Apr 28, 2009 06:35 AM
Ryan T
1997 - 2003 F150
Apr 25, 2008 10:27 PM
kky
Sep 14, 2004 07:49 AM
mwierowski
May 4, 2004 11:43 AM
