My 1995 E-150 has been diagnosed with worn upper ball joints that need to be replaced. Also referred to were some bushings that may need to be replaced. I have done alot of mechanical work, but never ball joints. Is this a trick that a backyard mechanic can pull off? What is the best way to approach it?
Do you have control arm suspension or twin I-beam?
No ball joints on twin I beam.
Ball joints not for the beginner. (if you have them) They need to be installed in conjunction with a complete front end alignment--so you're going to pay for that anyway--let the shop do and be responsible for the whole thing.
But, back to the original question about twin I beam vs. control arms..... if they are telling you ball joints with twin I beams I'd find another shop.
Actually a 95 E-van has twin I-beams and ball joints.
They are pretty easy to replace if you have a ball joint press. Hopefully a local parts store would rent you a press.
I've done tons of ball joints so for me it's an easy job but I do think that most backyarders could do it if they are fairy mechanically inclined. For good instructions I would recommend that you pick up a shop manual for your van or check out http://www1.autozone.com/servlet/UiB...3d8017787b.jsp
Unless you disturb the upper ball joint adjusting cams, and you shouldn't have to, you will be ok without an alignment after as long as your alignment was good to start with.
Yes, my 1992 has balljoints and a twin i-beam axle.. It is possible, but it's a good idea to go ahead and do the lowers as well, as you may damage them in removing the uppers.
Thanks for all the helpful input, and especially for the link to Autozone. I will be taking a closer look at this front end to see if I want to tackle it.
The job itself is not complicated, if you've replaced a wheel bearing or brake rotor you weren't far from what needs to be done. But it does require a special tool or a hydraulic press to replace the ball joints themselves.
