Van Turbo Question
Old Aug 19, 2021 | 10:17 PM
SVandal's Avatar
SVandal
Originally Posted by Sous
Sometimes you can find the odd ball parts by using https://www.car-part.com
I have used the service a couple of times with good success.
I’ll give them a try. I found one on eBay for 215 shipped. Seems like a middle of the road price. I’m planning to rebuild it anyways while I have apart so may go that way. Just need to strip off everything I’m not going to use and get it listed.
Old Aug 19, 2021 | 10:32 PM
FinnishStroker's Avatar
FinnishStroker
I bought an GTP38 used in International T444E from eBay,for my custom stock turbo project.
Those can be found with an 1.0 A/R exhaust housing with no wastegate.
Old Aug 19, 2021 | 10:47 PM
SVandal's Avatar
SVandal
i looked those up. Judging by the eBay listings, I’m not certain that they all have the right compressor outlet. I need to be able to go to the larger SD plenums without adapter boots. I want the least restrictive flow I can get to keep temperatures down. I’ll keep them in my scan, maybe some of them would work.
Old Aug 20, 2021 | 09:24 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
That sounds like a viable option if the other sources don't pan out.
I see you have mentioned SD plenums a couple of times. Have you looked into the billet inserts for the plenum covers? They are relatively low cost, but provide a good amount of confidence and reliability to the intake system.
Just a thought and keep us updated!
Old Aug 20, 2021 | 09:34 AM
SVandal's Avatar
SVandal
thanks for the recommendation. I’ll add them to my list.
Old Aug 23, 2021 | 07:22 PM
SVandal's Avatar
SVandal
Turbo and pedestal both showed up today. The van plenum and turbo like like they will match right up to the SD engine/intake plenums. Exhaust outlet on the turbo looks like a match for the OBS down pipe. I just need to take the EBPV out and weld the holes up. The Beans flange EBPV delete flange makes it into a SD sized outlet.
thank y’all for the help with this!
Old Aug 23, 2021 | 10:08 PM
Sous's Avatar
Sous
FTE Emeritus
Sounds good and we are pleased to read your parts are fitting together well. Keep us updated as the project continues and don't forget we love pictures!
Old Aug 23, 2021 | 10:10 PM
SVandal's Avatar
SVandal
I’ll post them up when I have turbo and pedestal and up pipes. That way it’s all fit together.
Old Sep 6, 2021 | 09:56 AM
SVandal's Avatar
SVandal
Doing the EBPV the old fashioned way. I need to use the van outlet to mate with the OBS down pipe. Just need to use a die grinder to clean them up.
Old Sep 6, 2021 | 10:25 AM
SVandal's Avatar
SVandal
All cleaned up.
Old Sep 6, 2021 | 11:40 AM
Sous's Avatar
Sous
FTE Emeritus
Looking good sir. Keep us updated.
Old Sep 7, 2021 | 07:57 AM
RA101725's Avatar
RA101725
Banned
Yeah that might be your only option anyway if you need that outlet adapter to mate to an OBS downpipe. Riff-Raff sells a van turbo outlet adapter but it's for super duty downpipes.
Old Sep 7, 2021 | 04:03 PM
  #28
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
Please share pics when the time comes, taking notes for my 97
Old Sep 7, 2021 | 09:01 PM
  #29
SVandal's Avatar
SVandal
I have a SD turbo and Intercooler setup if you want to go that route. Just need to maybe get a drivers manifold, up pipe bolts, and intake plenums.
Old Sep 10, 2021 | 12:02 AM
  #30
alaskapilot95's Avatar
alaskapilot95
How’d the conversion to the van turbo go? I have one in my super duty. I don’t really have anything to compare it to as I came from a worn out engine and turbo and put a good engine and rebuilt the van turbo and installed them in my truck. I know I don’t have to worry about egts much unless I’m pulling heavy stuff. I make about 23-24psi. I wish I had put the balanced assembly in when I had it all apart before to get the benefits of the better turbine. It does take a second to spool but once it does it does good.
