Minimum Air Pressure before Warning Light Illuminates
Good morning all,
I have a 2022 F250 Tremor. What are the Minimum Air Pressures before Warning Light Illuminates? The pressures were set to the sticker values and the truck is a bit rougher than it needs to be. Yes, I know this is a truck. My first was 2002 F250.
I don't currently have ForScan, but would like to get it some time in the future.
Thank you!
Thank you!
Our truck’s tire pressure specs are 60 F / 80 R. I’ve had the front tires down to as low as 50 psi cold without a TPMS alert.
The TPMS alerts if the rear tire pressure falls to below 65 psi, but it seems to take a while.
So, it seems that a >15 psi drop will (eventually) cause an alert.
On the other side, it seems that I have to inflate the tires to 60 F / 80 R to turn off the alert.
HTH,
Jim / crewzer
HTH,
Jim / crewzer
I do scan the alert when I start the truck, but, if the values are close to where I set them, then I switch off that screen and ignore the smart telltale icon.
However, when we’re fully loaded and the tires are aired up to spec, then I pay closer attention. Accordingly, I decided against lowering the pressure target valises (and corresponding alert thresholds) with FORscan.
HTH,
Jim / crewzer
HTH,
Jim / crewzer
The following users liked this post:
