Carb Issues
Old Aug 16, 2021 | 12:49 PM
Fordf1006578's Avatar
Fordf1006578
Post Carb Issues
On my 1965 Ford F-100, I have an Edelbrock 1404 carb. After driving, fuel leaks into the vacuum advance to distributor. Then the truck doesn't start, only turns over. Also, my fuel economy is down significantly, almost seems that I only get 5 mpg. What could be causing this? Thank you
Old Aug 16, 2021 | 02:24 PM
66v8baby's Avatar
66v8baby
It sounds like either the floats are sticking with the needle open or the fuel pressure is too high, overfilling the bowl.
Old Aug 16, 2021 | 02:56 PM
dubya TF's Avatar
dubya TF
Check your engine oil too. Could've fuel washed the engine a bit with stuck floats.
Old Aug 16, 2021 | 03:14 PM
Fordf1006578
My pressure regulator was set at 5, so I lowered it down to 4.
Old Aug 16, 2021 | 03:26 PM
Christmas's Avatar
Christmas
Is that a known number or what it says on the regulator?
Old Aug 16, 2021 | 04:31 PM
Fordf1006578
From the regulator. When I bought the truck, it was set ant 5 1/2. A buddy of mine runs his at 3. My local mechanic suggested to keep it low in the summer, then raise it back up in the winter. But other than adjusting the reg, I am still curious WHY fuel is seeping into the vacuum line. Any ideas.
Old Aug 16, 2021 | 04:34 PM
Fordf1006578
On another note: My mechanic suggested installing electric fans on a new radiator. What are you thoughts?
Old Aug 16, 2021 | 04:58 PM
dubya TF's Avatar
dubya TF
Lemme guess, it's one of these type deals....
Old Aug 16, 2021 | 09:23 PM
Fordf1006578
Exact! Are they junk?
Old Aug 16, 2021 | 09:35 PM
Christmas's Avatar
Christmas
I put one of those in a few years back. Worked ok for awhile but now it's backed down to 1 and still reads 5.5-6psi. I have a holley dual feed regulator that needs to be installed some day.
Old Aug 17, 2021 | 04:08 PM
dubya TF's Avatar
dubya TF
They are in fact, junk. Prone to internal leaking due to not being assembled from finely machined parts and also hyper-sensitive to vibration. Some may work well for a period of time but still not a quality part to rely on.
Old Aug 17, 2021 | 07:02 PM
Fordf1006578
Do you know of a better option to use? Maybe better brand?
Old Aug 17, 2021 | 07:16 PM
Christmas's Avatar
Christmas
Holley 12-804 Chrome Carbureted Fuel Pressure Regulator | eBay
Old Aug 17, 2021 | 08:20 PM
Fordf1006578
Thank you for the link on the reg. What is your recommended setting on psi, as that reg is 1-4. Thank you
Old Aug 17, 2021 | 09:46 PM
Christmas's Avatar
Christmas
5psi works well on most all carbs.
Mitchapalooza85
16
Feb 22, 2019 03:26 PM
Dads76XLT
Jul 28, 2017 03:30 AM
Canus
Dec 7, 2014 09:39 AM
Rocketdog2013
May 5, 2013 04:37 PM
dorf dude
Feb 17, 2013 08:04 AM
