Sponsored by: Real Truck
Steering Issue
Old Aug 15, 2021 | 01:02 PM
BlueBeauty's Avatar
BlueBeauty
Steering Issue
While driving recently my steering has become annoyingly stiff. This only happens from a dead stop or when my foot is not on the gas pedal. When I'm on the pedal it turns just as easy as if it where brand new. The power steering pump is only 2 1/2 years old and i have an 03' F250. I thought maybe it was the pump i put some ATF fluid in the reservoir but still no help. Haven't been leaking fluid from anywhere including the power steering pump. Could the be a belt issue? A steering gear box issue? Anyone have any ideas?
Thanks for any help you all may have.
Old Aug 15, 2021 | 01:16 PM
marksman76's Avatar
marksman76
maybe there is air in the lines?
Take the cap off, drive around the block slowly.
Keep it running when you get back, and add more fluid if needed.
Do not over fill it.
Have someone turn the wheels almost all the way left and right while you watch the fluid level.
Just my amateur thoughts.
Old Aug 15, 2021 | 01:48 PM
BlueBeauty's Avatar
BlueBeauty
Just tried that. If it got better it was very marginal at best. Thanks tho for the advise!
Old Aug 15, 2021 | 02:03 PM
marksman76's Avatar
marksman76
How loose or tight is the fan belt that drives the power steering pump?
I suspect you have only the one serpentine belt.
Have you checked the adjustment?
Old Aug 15, 2021 | 05:48 PM
BlueBeauty's Avatar
BlueBeauty
It's very tight! I just discovered that if i throw the truck in neutral and rev the engine to get my rpms up it turns freely. I'm thinking there is something up with the pump
Old Aug 16, 2021 | 04:16 PM
bajaphile's Avatar
bajaphile
Sounds like the common issue with these trucks. I did idler arm first, then PS pump, then finally new steering box. The steering box solved it for me.
ulmapache
Mar 14, 2020 06:40 PM
coolbrze
Jul 21, 2017 08:41 PM
eldonkey
May 18, 2011 07:27 AM
dvdgzzrll
Oct 17, 2010 06:47 PM
dennis299
Jul 19, 2008 09:54 AM
