I'd have left a nipped quarter in there for insurance against the UVCH backing out again. But I'd leave it for now, the problem may not return.
Did you inspect the underside of the wire harness where it meets the 42 pin? Common place for the wires to wear on the valve cover. Can make intermittent shorts.
I replaced the UVCH with a Dorman, I just didn't have pics of it installed. Yes I inspected the 42 pin wire. It has aluminum sheathing around the cable wrap and nothing is worn through.
