UVCH odd ohm readings and behavior
yeah 25 ohm is alot and i really feel like you would notice that in the way it runs. Its really easy to have a lead on the wrong pin. I have and i usually figure it out because of the results.
What was your fuel economy on your 1300 mile trip?
I calculated a 1200 mile trip in my 7.3 van. All highway average speed was probably in the 77-80 range. I got 18.7 mpg. My van is probably 2k lighter than my 4wd excursion.
I'm honestly not sure, but I think it was around 12-13. This was with a 3500# trailer and the truck filled with about 1000-2000 pounds of stuff. Speed was 70-75.
You are checking ea wire. Your leads are basicly going on ea end of the same wire that runs from idm to 42pin. Hopefully i explained that right.
very thin back probes something like these work great when ohming out wire harnesses . I recently had to Ohm out wires from the PCM to the solenoid pack on my transmission and the regular test leads that come with the multimeter were too fat. Of course using these to stab into wire insulation would not be advised
Could be the loose UVCH connection and need a $0.50 fix
Could be a bad UVCH and need replacing.
Could be (and hopefully not) a short fried another IDM. When my IDM went out I had my passenger side completely out, I would expect a code though.
My thought is still that you have an issue under the valve cover with the UVCH connection at the gasket, likely burnt or causing a short. It just seems too weird that you’re on your 3rd IDM with such low miles. Something is frying them IMO.
No way was I driving it. It was surging from 500-1500 rpm just sitting there parked. Not sure how the IDM would be fried so quick. It drove well on the way home from my buddies house, and today was the only time I started it since I drove it back from my friends.
I need to get Forscan set up and do a buzz test. I have the USB to ODB adapter, just need to get Forscan communicating with it.
If it's an issue with the UVCH and I need to pull the valve cover, I'm replacing the gasket and harness. I'm not messing around with shimming a quarter in there. With my luck the connector will break at some point and I'll have a quarter banging around in my valve cover. I'll do both sides as well.
An arc from a bad connection and/or short in the harness could fry the IDM. I believe a capacitor or something inside, some videos of guys opening up and resoldering a new one in. Above my pay grade.
That could not be the issue and I didn’t mean to push you to wort case. When I was researching for my fix, many users here experienced similar issues that only had a bad connection at the UVCH. Again, so many IDMs in a short period of usage is just odd as there are plenty of trucks running around with 5 times the miles running around on their original. Could be bad luck though I suppose. I still think you are going to find a visibly damaged UVCH under the passenger cover.
As for replacing vs the $0.50 fix, I don’t blame you. I did the same thing. Getting into the valve covers isn’t as difficult as it is inconvenient. And to replacing the driver side too, you can, but probably not necessary. Personally, I would do the passenger side and confirm your ohms and that you’re running right before swapping the driver side if you do.
Also pulled codes U1262, P0500, U2015, B1483, and P1876. Those don't seem related to the injectors so I'll add that to my list of things to do to this vehicle.
You are having an intermittent problem. Clear the codes. Next time you start it need to monitor icp. Need to know if icp maintains when you have your next problem. I guess your uvch could still be the issue. Although i thought you got good resistance readings from the 42 pin connector.
You ordered dorman uvch. I think they redesigned the connector in theirs. A few years ago the dorman uvch was to be avoided. Are any of your other sensors or ipr dorman brand?
Everything is original except for IDM and crank sensor. ICP was already checked and it's fine. I did not get "good" readings from the 42 pin. All passenger side sensors were higher than driver side by about 1.5-2 ohms, and 1,3,7 were different from 5. This lined up with the high readings from the IDM connector that I took the day prior. I believe it may be a combined issue between a bad uvch and a wiring harness chewed by mice. The harness was already repaired at a shop once to the best of my knowledge, due to mouse damage. Dorman UVCH had great ratings on amazon and it has the solid internal connector.
The matting on the fender liner also turned into great nest material for Mr. Mouse.
I'd have left a nipped quarter in there for insurance against the UVCH backing out again. But I'd leave it for now, the problem may not return.
Did you inspect the underside of the wire harness where it meets the 42 pin? Common place for the wires to wear on the valve cover. Can make intermittent shorts.
