Problem with parking lights
Old Aug 12, 2021 | 10:04 AM
Jimmyr1616162626's Avatar
Jimmyr1616162626
I started having a fuse blow leading to my lights after some investigation I found burn Mark's on my swich and connector going into the swich. I replaced both and I'm still having my fuse blow. From what I can tell it looks like the problem is the wire going to the parking lights(a tan with white stripe wire) dose anyone know where I should look to fund the cause of the problem? can a blown bulb in my roof marker lights cause my fuse to keep blowing?
Old Aug 16, 2021 | 09:43 PM
Perk85F250's Avatar
Perk85F250
Marker bulbs, any bulb I suppose, can cause a short to ground. Look at it. Is the inside of the bulb (globe) black? If so, it is likely the cause. Inspect your trailer light plug and wiring in the rear bumper as another possible cause for blowing the fuse.
The_Truck_Dude
Electrical Systems/Wiring
15
Apr 6, 2019 01:48 PM
huskyfan68
Apr 20, 2017 01:21 PM
WolfHunter
Apr 8, 2017 07:47 AM
aphotic26
Aug 26, 2010 09:42 PM
bdunegan
Dec 7, 2006 01:36 PM
