Sponsored by: Real Truck
Trailer fuse blows
Old Aug 25, 2010 | 04:33 PM
aphotic26's Avatar
aphotic26
Trailer fuse blows
Hey folks I have a 2001 F250 SD with 276,700 KM
This is not a related superduty question but its worth a shot.
I need my lights working on my trailer, its a single axle 3500lb 10 ft and I added two marker lights on the fender. I have two marker lights nicely wired to the green/brown wire, everytime with a 20A fuse it blows, I tried a 25A but nothing will turn on...once I disconnect the marker lights they everything else works.
Im working on it as we speak and having problems trying to resolve it.
Thanks folks
Old Aug 25, 2010 | 04:56 PM
cdrmotorsports's Avatar
cdrmotorsports
First, don't up the fuse to a 25A, that'll just cause more problems if it melts something. So the problem has to be with the marker lights that you added. Are you sure you are wiring them in to the correct wire? Most trailers just use brown as a running light wire. I'd check with a test light just to make sure. If you are sure you have the correct wire, make sure that the wiring isn't grounding out somewhere or anything like that.
Old Aug 25, 2010 | 08:48 PM
RV_Tech's Avatar
RV_Tech
If it's blowing a fuse, it has a short and, as already noted, putting in a larger fuse is not the way to go. For just marker lights, you are liklely already overfused.
Steve
Old Aug 25, 2010 | 09:04 PM
cdrmotorsports
Rv_Tech is right. I'm pretty sure the fuse is only supposed to be a 10A for the trailer running lights.
Old Aug 25, 2010 | 09:39 PM
Pinky Demon's Avatar
Pinky Demon
Having the same problem. The #6 Trailer Tow Turn/Stop relay is a 20 amp fuse FYI.
Old Aug 25, 2010 | 10:07 PM
kparret's Avatar
kparret
Not sure why your marker wire is green/brown. Should just be a brown wire if it's an OEM or professional install. Might explain your blown fuses. If you have a multimeter, I'd check it each pin to make sure it's wired up right.
See this helpful information on eTrailer:
Trailer Wiring Diagrams | etrailer.com
Old Aug 26, 2010 | 10:57 AM
cdrmotorsports
Right, be he's having a problem with the running lights, not the turn or stop lights. Those are on different fuses. There are many fuses for the trailer tow package.
Old Aug 26, 2010 | 08:07 PM
aphotic26's Avatar
aphotic26
great thanks guys for the help!
Old Aug 26, 2010 | 09:42 PM
Pinky Demon
Are you loosing turn signals and brake lights at the same time OP?
Ricopowers
Nov 3, 2024 02:25 PM
dadriva
Feb 14, 2017 09:21 AM
02SuperPoop
Dec 29, 2013 09:54 PM
LordMr.Ford
Sep 13, 2013 09:12 PM
shok47
1983 - 2012 Ranger & B-Series
Nov 10, 2012 09:36 AM
