Ol' Snort
Old Feb 6, 2026 | 04:27 PM
  #61
Flabmobile's Avatar
Flabmobile
Stock size master.
The pedal is pretty firm but the rear brakes do not bite hard enough to hold solid. When it was on jack stands, I had someone hold the pedal and I could not turn the wheels with a prybar in the lug nuts. I thought that was good enough but when it was at the muffler shop, only the fronts would hold. We tried an experiment with the fronts on the ground and the rears on the truck. He pulled forward and the rear wheels rolled on the truck deck with me holding full pressure.
I'm wondering if the master cylinder could be bypassing pressure on the rear side and not holding. The only time I have had a master cylinder go bad it had a leak. I'm just wondering if the leak is internal. We have all dealt with new parts that failed right out of the box. That could be the issue.
I haven't driven this truck in so long I forgot what "normal foot pressure" feels like. There is also no vacuum at the booster since I have not started it yet. I didn't want to lite this candle yet without exhaust. If there is a knock in the engine, I want to hear it. Shows you my level of confidence. I crammed two-years of work into six. Don't want to screw it up now.
Old Feb 6, 2026 | 08:09 PM
  #62
somethingclever's Avatar
somethingclever
Could be a bad master. Sounds like it really.
Old Feb 15, 2026 | 01:41 PM
  #63
Ralston76's Avatar
Ralston76
It sounds like the master cylinder to me also. When mine went, I didn’t have any leaks so it would’ve been the seals inside letting fluid blow past and not giving me any brake pressure but since you haven’t started the truck and you don’t have the booster helping out, it would be hard to rule out the booster.
Ralston76
271
Apr 25, 2026 01:37 PM
eman92082
May 9, 2020 09:34 AM
Maverick68F100
20
Jun 29, 2016 11:36 AM
Muppy1840
26
Feb 6, 2015 09:24 PM
Wyatt66f100
Sep 17, 2011 12:32 PM
