Steering column interchange
Old Aug 11, 2021 | 02:10 PM
Mikulh's Avatar
Mikulh
Can you tell me if an automatic non-tilt steering column from a 1978 F100 will work in a 1975 F100? What years will interchange?
Old Aug 11, 2021 | 03:25 PM
bboteler's Avatar
bboteler
My understanding is as long as both truck are the same either manual or power steering the columns should swap.
Old Aug 11, 2021 | 10:51 PM
redroad's Avatar
redroad
You don't specify 2wd or 4wd so here are the Master catalog parts #s diagrams. They should point out any
differences in the years you specified 1975 and 1978 fixed auto steering columns.
2wd
4wd
Old Aug 12, 2021 | 08:57 AM
Mikulh's Avatar
Mikulh
Sorry, I didn't realize there was a difference. 2WD
Old Aug 12, 2021 | 12:46 PM
meangreen92's Avatar
meangreen92
In the new ZIPTIES N BIAS PLIES video, he road trips to buy a '79 F350 ex-U-haul truck equipped with an NP-435 or other four speed, and drives it home, and you can see that some previous owner had swapped an automatic column in there!
Old Aug 13, 2021 | 08:37 AM
flowney's Avatar
flowney
I believe that the 78/79 models moved the Neutral Starter Switch from the steering column to the transmission.
Old Jan 15, 2025 | 12:07 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
I have a 78 with it on the column, a 79 on the tranny
Old Jan 15, 2025 | 01:29 PM
75over77 F100's Avatar
75over77 F100
Did all of the 73-79's have neutral safety switches?
Old Jan 15, 2025 | 02:39 PM
dlburch's Avatar
dlburch
no, only trucks equipped with automatic transmissions.
F100-1969
Oct 11, 2018 02:14 PM
The blue oval
Nov 6, 2013 12:55 PM
dlhngrs
Aug 29, 2004 10:30 AM
David Campione
Oct 8, 1999 01:55 PM
