Transmission issues
Old Aug 10, 2021 | 12:13 AM
michhhh's Avatar
michhhh
Transmission issues
Did a tranny service on my 14 ecoboost. Dropped pan and filter swap and added 7.5 quarts of Mercon 4. Now the tranny is whining and not going in gear very well. Fluid level is good but not sure of the issue.
Old Aug 10, 2021 | 01:48 AM
ford390gashog's Avatar
ford390gashog
Did you use the correct OE filter? They will suck air if the wrong fluid is used and cause extensive damage.
Old Aug 10, 2021 | 02:06 AM
michhhh's Avatar
michhhh
so this is the filter I used originally as this is what is said to fit my truck but I’m pretty confident it’s the wrong one now
https://www.oreillyauto.com/detail/c...kit/ptq7/fk405
Old Aug 10, 2021 | 05:33 AM
projectSHO89's Avatar
projectSHO89
What's "Mercon 4"? Never heard of it....
Old Aug 10, 2021 | 10:28 AM
gDMJoe's Avatar
gDMJoe
Exclamation
michhhh... added 7.5 quarts of Mercon 4....
Should have been MERCON LV.
Old Aug 10, 2021 | 01:52 PM
Lime1GT's Avatar
Lime1GT
That's probably what he meant if looking at it like roman numerals. IV ---- LV or 4 is close to 5 on keyboard mistake.
Did he remember to install the filter to valve body seal if there was one in the kit.
Old Aug 10, 2021 | 02:48 PM
RLXXI's Avatar
RLXXI
I wonder if the old filter seal stuck inside the valve body and they didn't see it then tried to stab the new filter in place. I've done it my self many moons ago. Causes the same symptoms.
Old Aug 11, 2021 | 01:32 PM
2jhanna's Avatar
2jhanna
ive had this same concern also as I'm nearing a tranny service and new pan with plug.
isnt the motorcraft 188 filter the correct one, or does it matter what engine/options the truck has ?
Pat Taugher
Jan 1, 2015 05:51 PM
calvinjwilcox
Apr 21, 2010 08:39 PM
dew2
Jan 7, 2009 02:25 PM
stroke-of-luck00
Oct 15, 2007 10:20 AM
JFUSION
Escape & Escape Hybrid
Nov 12, 2006 03:42 PM
