Trailer disconnected icon
Old Aug 9, 2021 | 09:53 PM
Frank79's Avatar
Frank79
New 2020 truck with a new 2021 car hauler.
lately I’ve been getting the “trailer disconnected” display on the dash while going down the road. Sometimes it happens others it’s fine.
today when it happened I pulled over. I confirmed All the lights on the trailer worked, brakes, turn, running etc, but the icon was still there. Wiggled the trailer plug and everything was gtg. Few miles later same thing. This time I lost trailer brakes, but all lights were working.
is my plug bad? Something else?
Old Aug 9, 2021 | 10:02 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Usually when that happens it is a ground issue.
Try tightening up the plug contacts so they fit together tighter.
Old Aug 9, 2021 | 10:08 PM
KU4OJ's Avatar
KU4OJ
Look under the rear of the truck behind the bumper and near the spare tire. There's a few connectors there that can get moisture in them and/or corrode and raise all sorts of havoc. Dismantle every connector you can find, clean and put some dielectric grease in there. Solves all sorts of issues.
When my new truck gets here greasing those connectors will be done the first week I have it, I have heard so much about the trouble they can cause.
Old Aug 9, 2021 | 10:16 PM
Frank79's Avatar
Frank79
if it’s a ground issue, why would the lights on the trailer work?
Old Aug 9, 2021 | 10:18 PM
Frank79's Avatar
Frank79
I’ll take a peek tomorrow. I’m do for a oil change. Is this something the dealer will do or is it up to me to grease everything up? Truck only has 5k miles
Old Aug 9, 2021 | 10:28 PM
Frank79's Avatar
Frank79
sorry for my ignorance. Where in the connector do I apply the grease? I just read in a few different sites “shouldn't be applied directly to the mating surfaces (pins and sockets) of an electrical connection”
Since dielectric grease is a silicone grease, it should not be used on silicone-based rubbers or plastics, as it will break them down over time. The grease does not conduct electricity, so it shouldn't be applied directly to the mating surfaces (pins and sockets) of an electrical connection.May 24, 2020“
Old Aug 9, 2021 | 10:33 PM
ford390gashog's Avatar
ford390gashog
Because the trailer is grounding through the hitch. Separate the truck and trailer and just use the 7 pin for testing.
Old Aug 9, 2021 | 10:50 PM
Frank79's Avatar
Frank79
makes good sense 😎
ill try it tomorrow
cgm73
Oct 13, 2019 07:35 AM
Exposed
All Things Towing
36
Aug 18, 2019 12:06 PM
13Raptor
2009 - 2014 F150
Apr 3, 2017 12:20 PM
oldrifleman
2009 - 2014 F150
Apr 28, 2015 12:17 AM
DrSwinestein
Aug 22, 2010 04:38 PM
