Need recommendation for pistons
Old Aug 6, 2021 | 07:10 PM
KnfMkAR's Avatar
KnfMkAR
I need a recommendation for pistons on this 351w rebuild.
Just got the 351 Windsor (from a 89 truck) back from the machine shop. Cleaned, magna-fluxed, cam bearings pressed in, decks flattened, bored 0.030 over (had gouging).
Also had the crankshaft ground/polished and have purchased the relevant bearings.
We are using a top-end kit. All aluminum. Heads are 62cc chamber volume.
Comp cams XE268H camshaft w/ new lifters
Ideally compression would be between 9:1 and 10:1
Ideal RPM range would be 1500-6000rpm. Going in a 87 flareside, so not doing any towing, but still a truck. Will have a 5 speed transmission and 3.55 gears.
What would be a good set of pistons for the above?
Old Aug 6, 2021 | 07:22 PM
ford390gashog's Avatar
ford390gashog
Well it's definitely the wrong time for pistons, the machine shop should have told you that. You need the pistons in hand before your bore as doing a .030 blind can lead to piston fitment and ring pack issues. Did the machine shop give you all the measurements of what they did? There is a ton of variation between piston manufacturers and production runs on parts.
Old Aug 6, 2021 | 07:47 PM
Mudsport96's Avatar
Mudsport96
X2
Most pistons come with boring directions.
I believe the speed pros i used last stated bore .0003 passed piston size and hone to .0005 passed. Been a few years though. Also, if you had the crank cut and you are getting new pistons, its a good idea to rebalance the rotating assembly as well.
But if you can wait till tomorrow i can get into my speedpro book and just dig up a couple of numbers to give you an idea.
Old Aug 7, 2021 | 10:58 AM
SFaulken's Avatar
SFaulken
Yeah, I don't think I've ever had an engine bored, without sending along the pistons, so they could bore match them. For your purposes, I'd probably just go with like a flat top Sealed Power hypereutectic. I mean you could splurge on forged pistons, but why?
Old Aug 8, 2021 | 09:30 AM
torq'ta 5 8's Avatar
torq'ta 5 8
take your motor back and get him to order and install, that way its on him, if he gave you any kind of warranty.
Old Aug 8, 2021 | 10:44 AM
Mudsport96's Avatar
Mudsport96
I agree with all of the above.
But, if you choose to just get pistons, here are some numbers you could have the machinist look into.
Forged
Hypereutectic
Bottom one is factory part number, would have to find out the additional number for an overbore size
Fordenthusiasts
Nov 12, 2012 08:38 PM
Blue Rebel
Feb 10, 2009 02:07 AM
1963f100
May 9, 2007 03:50 AM
wvbogger
Aug 6, 2006 02:06 PM
Chris_ce
Oct 3, 2003 06:35 PM
