Tapping Noise 7.3
Old Aug 6, 2021 | 11:34 AM
Bsfu211's Avatar
Bsfu211
Trailering
Tapping Noise 7.3
Hi Guys, just noticed a tapping noise from my 7.3. 191,000 miles. Can anyone tell what it is. I only hear it at idle.
https://youtu.be/m7-EFIqQy-w
Old Aug 6, 2021 | 11:53 AM
RacinJasonWV's Avatar
RacinJasonWV
Welcome to FTE!
Sounds normal to me.
Sometimes an exhaust manifold or uppipe leak can sound like a tap/knock.
Your link didn’t come through well so I’ll try and get it here for you.
Old Aug 6, 2021 | 01:36 PM
Bitterroot Diesel's Avatar
Bitterroot Diesel
Former Vendor
That's your truck saying it wants BDP 238/80s
Can't pick up anything from the video, but it's possible to have a fuel knock from unbalanced injectors.
Old Aug 6, 2021 | 01:54 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Welcome to the FTE!
Sounds normal to me as well.
Old Aug 6, 2021 | 03:24 PM
PriusLover's Avatar
PriusLover
Wouldn't this show on a CCT?
Old Aug 6, 2021 | 03:28 PM
Walleye Hunter's Avatar
Walleye Hunter
It's the engine running, when you can't hear it any more, you got problems.
Old Aug 6, 2021 | 05:18 PM
Jimmy's Pilot Service's Avatar
Veteran: Navy
Sounds like a 7.3 singing the song of the fuel gods as only a 7.3 can.
Old Aug 7, 2021 | 03:07 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
What they said. Does not sound "bad".
A cylinder contribution test would help identify if there is a serious concern.
Did you change oil recently?
Old Aug 7, 2021 | 07:16 AM
Listor's Avatar
Listor
Sounds normal, you may have a little exhaust leak, but don't we all !
Old Aug 7, 2021 | 07:55 AM
bsiliani's Avatar
bsiliani
Sounds normal.
I might add that changing to a synthetic blend and adding a fuel additive seemed to quiet mine down some.
But I like to spend money and it probably does nothing at all except make me feel better.
Even new injectors are loud until they break in many thousands of miles.
Old Aug 7, 2021 | 04:19 PM
z31freakify's Avatar
z31freakify
I hear it, could be injectors like BRD mentioned. But like everything could be just the nature of your engine, some 7.3 engines are loud AF then there's others that are quiet as the newer diesel trucks
MTP55
Aug 7, 2021 07:20 AM
ford300fan
General Diesel Discussion
May 22, 2017 05:28 AM
daniel1997psd
Oct 5, 2016 10:19 PM
FUJINAMI1293
Jul 17, 2012 11:04 PM
501 ford
Dec 28, 2009 11:18 AM
