Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Power Window Switch
Old Nov 16, 2016 | 07:06 PM
wnc05ford51K's Avatar
wnc05ford51K
Power Window Switch
Sometimes the power windows on the driver's front and passenger rear do not work at the master switch on driver's door. Rocking the buttons back and forth work at times. If I use the switch on the passenger door the window works normally. Are those separate switches? And does the bezel pop off to access the switches?
Old Nov 17, 2016 | 09:16 AM
tomw's Avatar
tomw
Yes, they are two separate switches. The 'master' has one for each window along with a disconnect to disable all the other switches. I don't think any smart box is involved in the passenger window operation, so it should be a simple switch. Most have a snap-on bezel, or covers over fasteners. I think the switch is a snap-fit into the door panel, but it is model year dependent.
Most times, you can remove the inner door handle, and arm rest fasteners, and then pop the door panel off, gaining enough room to disconnect the multi-wire connector to the switch. You may be able to clean the old switch, or get a replacement. I would note that I had to replace the power seat switch on an 07, and it was $$.$$, and was $$$.$$ at some sources. Made of unobtainium, I think, that or they really were proud of that switch. I think the window switch would be more, but who knows.
The switches are DPDT, swapping + and - connections as they are operated to reverse the motor as needed.
tom
Old May 24, 2019 | 05:27 PM
Defiant Lion's Avatar
Defiant Lion
Door switch, operating window
I would take off the door panel to get a real look and make sure it's not the assembly motor that holds & lifts the window up & down. These pieces of **** are horribly made to fail, plastic body's with a metal cap that will pop off or something inside will brake giving you a warning that it's on it's final farewell before taken a **** in your wallet & pissing you the **** off even more cause the other back passenger will follow the same fate. Be prepared for your front one's to add on somewhere down the line of more genius thought of equipment made to fail you dishing out more $$$ on **** that they purposely put into play so we feed on the quantity of parts that keep their greedy *** hands in our pocke
Old May 25, 2019 | 07:22 AM
tomw's Avatar
tomw
You do (should) know this post is going on 3 years old. Replies are likely not going to be too popular. Might want to consider looking at the date before posting.
tom
emik26
2004 - 2008 F150
Nov 26, 2011 09:25 AM
Big-Red-Lariat
2004 - 2008 F150
17
Aug 9, 2010 10:17 PM
romod
1983 - 2012 Ranger & B-Series
May 21, 2010 10:19 PM
wileecoyote76
1997 - 2003 F150
Oct 28, 2004 08:53 AM
tealboy1
1997 - 2003 F150
Oct 30, 2002 01:30 AM
