Odd exhaust behavior
Old Aug 1, 2021 | 09:13 PM
profwwacko's Avatar
profwwacko
Just had a new Ford NOS secondary air tube manifold installed. There is no comparison between this much superior now-discontinued part and the cheap replacements I could find.
But, when I first start the engine, it sounds like there is a huge leak in one of the pipes somewhere that gets louder under load.
After driving about a mile, the sound of the leak disappears and the exhaust is quiet as it should be, because everything is totally stock.
If I shut it off and restart it, the noise followed shortly by quiet cycle repeats.
I verified the check valve that is screwed into the secondary air tube manifold near the front, and it blocks all flow from the manifold, only allowing air from the pump to enter.
The MIL has not yet come on, but does this sound like some kind of fault in the combination valve/secondary air system somewhere?
ADVthanksANCE
-Jack (exhausted in central Texas)
'96 F150 Eddie Bauer 4.9L RWD
Old Aug 2, 2021 | 12:18 PM
torq'ta 5 8's Avatar
torq'ta 5 8
still, check for codes, could have stored codes.
Old Aug 2, 2021 | 12:29 PM
sandymane's Avatar
sandymane
You should know, being in Texas, what I mean by shooting from the hip. Here goes. EGR is bad and causes a vacuum leak and stops when it opens??? PCV bad or not in place from the work done??? O2 sensor??? Normal vacuum that comes with these trucks???? Someone with knowledge about your issue and give you more accurate ideas. It sounds like it stops happening when it goes into closed loop. Above post came in before I sent. I agree 100% about codes being checked.
Old Aug 2, 2021 | 02:52 PM
jas88's Avatar
jas88
First thing I would do is start it up cold and locate where the noise is coming from.
Old Aug 2, 2021 | 03:39 PM
sandymane's Avatar
sandymane
Very good idea when getting it to operating temp to run your codes.
stranskydw
22
Jan 12, 2009 04:14 PM
motox214
1983 - 2012 Ranger & B-Series
Sep 13, 2005 11:29 PM
lattices2
1978 - 1996 Big Bronco
Mar 18, 2005 12:58 PM
91fordinline6
Dec 14, 2004 01:41 PM
kelan
Nov 18, 2002 09:15 AM
