Electrolysis Tank
Old Dec 17, 2024 | 03:15 PM
  #46
1952henry's Avatar
1952henry
For sure, never used it it on parts with machined surfaces.
ive tried about everything, I like electrolysis, but Rust 911 works great as well. I bought a gallon for $70, it makes 16 gallons. I cleaned the inside of my flathead block with it.may try the DIY stuff. Still have most of my 911 gallon, however.
end of the day, I am fortunate to have my big blast cabinet. Easy peasy.
Old Dec 17, 2024 | 06:18 PM
  #47
8pack's Avatar
8pack
Originally Posted by 1952henry
DIY evapororust is citric acid and sodium carbonate, 40% of acid. Threads on the HAMB and utube.
for electrolysis tank, get some PH Plus in pool section at Wallyworld. Pretty cheap for a big tub. It is sodium carbonate. Have used it myself.
FWIW I use Rust 911 on smaller parts instead of Evaporust. They seem to be identical in performance. Amazon sells it concentrated for $80 which makes 16 gallons. That's $5 gallon vs. $20-$30 a gallon.
They work exactly the same in terms of time and effectiveness. They just be the same formulation but I have not checked the MDS because it works and it's cheaper. It makes it super affordable to do some medium sized parts and tons of small parts. I purchased it in July 2021 and am still using it up. It has been my go to unless I am doing big parts.
53 Meadow Green
Oct 8, 2010 03:48 PM
blueovalfan
General Automotive Discussion
Apr 15, 2008 08:50 AM
Beaux
27
Apr 1, 2005 06:19 AM
paragod
Nov 3, 2004 06:15 PM
Popa Tim
Oct 21, 2004 11:40 AM
