Trailer Disconnected Error Message
Old Sep 22, 2024 | 04:02 PM
Steveo024's Avatar
Steveo024
8th Gear
Originally Posted by BPofMD
Added to the above post...if the breakaway plug haS BEEN PULLED THERE IS HIGH amperage going to through the wiring and it can burn the wires so even AFTER replacing the switch you will have problems.
so how would I know which wires would be burned. The break away wires or electric wires for brakes. I have just put in electric over hydraulic and now I’m getting the trailer disconnected warning when braking at low speeds mainly.
Old Sep 23, 2024 | 09:09 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
If only getting the disconnect warning at low speeds, it is NOT the breakaway cable.
Old Sep 23, 2024 | 10:03 AM
Steveo024's Avatar
Steveo024
8th Gear
I have gotten the message at medium speeds usually after I have pumped the brake twice and then released and it pops up for a couple seconds and goes away. But mainly happens at low speeds. It just started after I did the disc brakes installed upgrade. It happens while parked as well if I pump the brakes a couple of times and it happens if plugged into either the socket in the bed or on the bumper. Very frustrating
Poncho450
Nov 23, 2023 10:22 AM
cgm73
Oct 13, 2019 07:35 AM
75thrngr
All Things Towing
29
Jun 4, 2019 08:17 PM
oldrifleman
2009 - 2014 F150
Apr 28, 2015 12:17 AM
buttz
May 17, 2007 05:44 PM
