Trailer Disconnected Error Message
Old Aug 1, 2021 | 01:54 PM
st.rodder2's Avatar
st.rodder2
Hi All, I have been getting a intermittent trailer disconnected message while towing my 5th wheel with my 2012 F250 SD. I have the in-bed trailer plug that I put in when I purchased the truck 5 years ago and never had any issues until lately. I will be driving along and the error message comes on then goes off. I checked all connections and are good. Today I connected to the plug at the bumper and it appeared to be worse and more frequent. I had the lights on and even with the message the lights still worked. It also feels like the brakes keep engaging and disconnecting when coming to a stop. Has anyone else had this happen? What did you do to fix the problem? Thanks in advance for your input. John
Old Aug 1, 2021 | 07:58 PM
senix's Avatar
senix
look at the wiring trailer side. Check the junction box where your 7 pin connects to the trailer.
Classic symptom of wiring issues with the trailer.
Old Aug 2, 2021 | 08:26 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
I too had that same problem with my 2005 F250. The only way I solved it was to install a new TBC . I bought an install the Tekonsha P2 and never had the problem again. Before that I removed and send the TBC to FICMRepair.Com and after I got it back it worked fine for a while but the issue returned after a number of months. That's when I decided to just remove the dumb thing. This also made my trailer brakes much more effective.
Old Aug 4, 2021 | 08:09 AM
st.rodder2's Avatar
st.rodder2
Has anyone replaced the factory brake controller with a after market one? Is it just unplug the original unit and plug in the new one? Does it effect any of the other wiring or the computer?
Old Aug 5, 2021 | 07:17 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
I replaced mine, but as I have an older truck I can't answer anything about yours. I used their wiring by cutting and soldering in the P2 I installed. No, I could not just "plug in" the Tekonsha into my Ford TBC connector wiring however Tekonsha does have this
Amazon Amazon
. Can not say if it will work or not.
Old Aug 6, 2021 | 07:57 AM
7.3F350's Avatar
7.3F350
What is the purpose/advantage of having the truck "being aware of" a trailer being hooked up? Is it for backup assist?
Old Aug 6, 2021 | 08:21 AM
djousma's Avatar
djousma
truck really isn't "aware", just features of builtin brake controller interfacing with instrument panel. You have connection problems with a prodigy, and you will get errors on it too..
A lot of focus is being placed on the controller in this thread. 99% of the time there is a bad connection somewhere on the trailer causing this. I've had the IBC on all 3 of my ford's since 2005 and never had a problem.
Old Aug 7, 2021 | 07:07 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Originally Posted by djousma
truck really isn't "aware", just features of built in brake controller interfacing with instrument panel. You have connection problems with a prodigy, and you will get errors on it too..
Not necessarily - as I stated above, I had the "trailer disconnected" prob with my 2005 built-in TBC once, sent it in for inspection and repair. Got it back and it worked fine for a time then started doing it again, Replaced it with a Prodigy P2 and never had the issue arise again.
Old Aug 8, 2021 | 09:18 AM
Irelands child's Avatar
Irelands child
For the 'missing' trailer, yes, that trailer JB in the pin box possibly has a loose connection. Mine popped up on a long mountain downhill in Arizona. Pulled the cover abd a wire nut came off too.
Aftermarket brake controller - Ford's IBC either works well or doesn't. My 2006 was fine, the 2011 not great with the setting at 9 with either the OE trailer drum brakes or the discs. Probably going to use either a Prodigy P2 or 3. One downfall is that you may need to have a fresh system flash to remove the OE software and the pop up code.
(NOW, will I get new post notifications or will I still be in the dark as I've been for the past few months even with the right CP boxes checked)
Old Aug 8, 2021 | 10:04 AM
HRTKD's Avatar
HRTKD
This post is to help out Dave, to see if he gets an email that the thread has been updated.
Otherwise, I can offer no opinion on the OP's problem.
Old Aug 8, 2021 | 11:38 AM
Irelands child
Whoopee!!
That, Jim. is the first response to any thread that I posted to or originated since last October. Maybe the site (my PC?) burp has corrected itself. I even sent the site team a couple emails plus wrote a sarcastic thread and never go any sort of response .
I wonder what what tomorrow brings
Old Aug 8, 2021 | 12:07 PM
Dono080's Avatar
Dono080
I just dealt with this exact issue back in May. For me I had borrowed a utility trailer from a friend, kept getting the trailer disconnected and the brakes felt intermittent on the trailer. Ended up being that the wire bundle on my friends trailer for one of the axles had been rubbed and cut one of the wires to the brake and the ground. Go for a drive and see if it occurs when you hit the brakes. I definitely think this is a trailer issue and not a truck issue.
Old Aug 26, 2021 | 08:49 PM
95F350CC's Avatar
95F350CC
St.Rodder, If you are still having problems, I had similar back in April. Random Trailer Disconnect messages while moving. Found I could replicate the problem by manually applying the trailer brake so I started troubleshooting the trailer connection, shortly I found that the rear axle brake wiring had broken and an exposed wire would rub against the axle while moving.
Also I discovered that the truck is too smart as the trailer disconnect message can be created by the brake or lighting circuits and possibly the battery charge circuit.
Old Aug 26, 2021 | 09:01 PM
HRTKD's Avatar
HRTKD
Larry's post reminded me that I had the disconnect message once. My trailer's breakaway switch got pulled while I was on the highway. I hardly noticed that the trailer brakes were on. Slight tug, but it could have been a head wind. But the disconnect message was a red flag. I pulled over and that's when I saw that the pin/plug on the switch had been pulled.
It's still part of the brake system, but a different part to look at.
Old Aug 27, 2021 | 07:06 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Added to the above post...if the breakaway plug haS BEEN PULLED THERE IS HIGH amperage going to through the wiring and it can burn the wires so even AFTER replacing the switch you will have problems.
