Engine load on transmission while stopped
Old Jul 31, 2021 | 07:07 AM
mhersh78's Avatar
mhersh78
I have a 2018 F350 platinum with the 6.7 I’m having an issue with the transmission acting like the torque converter is locked up when I stop at a light or just putting it in gear. While driving the transmission works perfectly. I just had the transmission fluid and filter changed. I have no codes that pull up on FORScan or any other reader. Any help would be great.
Old Jul 31, 2021 | 10:49 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Low transmission fluid can cause this. So can a missinstalled filter.
Old Jul 31, 2021 | 12:03 PM
mhersh78's Avatar
mhersh78
Fluid level is good and was doing the same thing before I had the transmission oil changed and new filter. I’m thinking it’s an electrical issue something not telling the transmission it’s out of park.
Old Jul 31, 2021 | 01:21 PM
Mark Kovalsky
The first thing to do is to read the codes. I recommend Forscan. You can download it free at www.forscan.org. Their webpage shows how to select an OBDII adapter. Once you have the codes we will have a starting place.
Old Jul 31, 2021 | 01:44 PM
mhersh78's Avatar
mhersh78
I have FORScan when I used it there were no codes on there I do have a license as well.
Old Aug 2, 2021 | 07:36 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Could very well be an issue with the converter.
Robclark
Dec 19, 2019 08:03 PM
Rick Stacy
Mar 11, 2017 10:17 AM
motoman
Feb 20, 2007 12:06 PM
99ExpyProblems
Jul 2, 2006 05:34 PM
A_G
1997 - 2003 F150
Sep 4, 2005 04:21 AM
