iPhone / Android
Old Aug 1, 2021 | 07:28 AM
Mlarv's Avatar
Mlarv
Originally Posted by rcinlaveen
UPDATE:
I previously had an iPhone 6s plus that connected and worked flawlessly from the day I purchased the truck. Plugged in to the usb port, or using only bluetooth, it worked perfectly.
The iPhone 12 plus will not work with carplay, but it will connect and I can talk on the phone, listen to spotify or pandora. No maps, text, and whatever else comes through carplay.
When the truck is turned off after I've driven with the phone connected, it will not connect with the phone at next start up. The F350 bluetooth connection must be removed from the iPhone and the iPhone must be completely deleted from the truck. I can reinstall, and it works (without carplay as described above) for the next drive, until turned off.
I travel for business, and the iPhone 12 has connected to a half-dozen different 2020 and 2021 vehicles and operated perfectly.
I connected the wife's iPhone 11, works perfectly. Connected an Android, worked fine.
I've attempted an update Sync 3 while connected to home Wifi, no update.
I've done the master reset multiple times, but it will not remove the original iPhone 6s plus, and it will not allow my iPhone 12 to connect to carplay or stay connected. I've scoured the internet looking for iPhone settings and have put everything where it should be.
It's got to be something simple that I'm missing...
Is the iPhone 6 still active? Is it set to primary phone? If so it needs to be deleted though the Bluetooth section along with all the other phones not in use. Sync will only allow so many phones to connect to it, maybe you have hit that limit.
I know when I rent cars (at least twice a month) I run into this.
nsrt
6.7L Power Stroke Diesel
Nov 24, 2014 01:22 PM
darren32
Aug 18, 2011 08:15 AM
Still Smoking
2004 - 2008 F150
Oct 15, 2009 06:56 AM
Balasharky
Utah Chapter
Jul 21, 2005 11:31 PM
ahawes
Dec 31, 2002 09:47 AM
