What else would cause this?
Old Oct 15, 2021 | 05:13 PM
  #46
Bessie's Avatar
Bessie
Originally Posted by hiball3985
But I don't know if the 239 used the same? I'm confused as to which gaskets you are using Are you saying you are using EBV gaskets on your EBU?
No - The FELPro gaskets I have been using are mislabeled as they say the EBU is a 55 and the EBV is a 54 - and that one size fits all. Of course those will not fit the 54 EBU, but those do fit correctly for the 55 EBV. The engine is a 55 EBV that I've put in my 54 that originally had a EBU that I still have. For gaskets this next time I have Victor brand gaskets for the 55 EBV.
When you gave me the measurement of the dowel, is that height from the deck?
Old Oct 15, 2021 | 05:19 PM
  #47
Bessie's Avatar
Bessie
Originally Posted by charliemccraney
I don't know the spec for the dowels. Measure the depth of the hole in the block, measure the depth of the hole in the head, measure a head gasket (since you have a few, use the thinnest). The dowel should be a little smaller than the sum of those.
Sounds good Charlie. I have never installed new dowels - how are they installed?
Old Oct 15, 2021 | 06:05 PM
  #48
charliemccraney's Avatar
charliemccraney
Pretty sure they just drop in. It's been a while. I don't remember having to do anything special to remove old ones or install new ones.
Old Oct 15, 2021 | 07:41 PM
  #49
hiball3985's Avatar
hiball3985
That was the total height of the dowel.
olsons13
Jul 8, 2010 06:46 PM
Fordtough300-6
Bronco II
Oct 21, 2004 07:52 PM
SShank42
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jul 11, 2004 12:01 AM
SShank42
Bronco II
Jul 6, 2004 07:51 PM
hipropos
Jun 15, 2004 05:06 PM
