Intake gaskets leak- water?
Old Jul 4, 2010 | 04:21 PM
olsons13's Avatar
olsons13
This is a 97 explorer V6, that has had radiator issues but not overheated, kinda. He had his radiator rebuilt,and the mech said check to make sure you dont have water in your oil, there was evidence of moisture but thats about it. So on the way home from the shop it starts heating up, stops tops off the rad. and gets home, now he has water in the oil, and wants to drain the oil to make sure 1) that this is now the next issue and 2)verify how quick the water is entering the oil. After draining the oil/ water, a 4-5mi drive home the result is alot of water in the oil. I know, dah! So another mech and the guys at the rad shop say its probably intake gaskets or cracked intake, now that I've got both intakes off I have questions for the experienced with this eng.
I could see water leaking, externally,where the thermostat housing attaches to the front of the pass side head, but from what I can see at this point I dont see how that would cause water to get into the oil.
And I dont see water passages in either intake to cause the leak, even if the gaskets/ intake were cracked. Unless water sitting on top "in the valley" is leaking in, but think its more a pressurized area problem due to the amount of water in the oil. I suspect that the leak is in one of the heads or the block, and figure we yank the heads and go from there.
In reading the posts here someone noted that man hrs is the same for heads as it is for pulling the eng, with 140k on the eng which direction is best, r/r the heads or swap out?
From reading the posts there seems to be experience here and not a bunch of bone head answers and remarks so, thank you for the assistance ahead of time.
Last edited by olsons13; Jul 4, 2010 at 08:06 PM. Reason: To re title for response purposes
Old Jul 8, 2010 | 06:46 PM
70f100longbed's Avatar
70f100longbed
It sounds like you have a SOHC engine from the description. Coolant cannot get into the oil from an intake leak on SOHCs. The other guy was thinking of the pushrod 4.0L. You prob have a blown head gasket. Be careful yanking the heads off, you need special tools to set the cam timing or you will bend valves.
rnelson664
Apr 29, 2021 09:56 AM
Berardini2121
1978 - 1996 Big Bronco
Apr 22, 2016 11:49 PM
kramttocs
Apr 18, 2016 03:56 PM
EatBeef
3.8 & 4.2L V6
Oct 19, 2013 07:24 AM
rjexpress
43
Jun 27, 2013 05:25 PM
