What else would cause this?
Old Jul 29, 2021 | 11:12 PM
Bessie's Avatar
Bessie
I have a 55 EBV 239 that allowed water to flow through the oil passages. I've changed head and timing cover gaskets. The FEL-Pro head gaskets are on correctly - front to front and one with an upside down face. With the top radiator hose off, I fill the radiator and water in the block raises to just below the heads. Once a little above the heads the water flows out the return oil filter passage as fast I fill it up - not a slow leak so this makes me think it is not a crack in the block or heads. What else can it be? Where else can water get into the oil passages?
Old Jul 30, 2021 | 02:11 PM
f5fordgirl's Avatar
f5fordgirl
One head could have a crack or bad casting letting water into the rocker oil passage.
Old Jul 30, 2021 | 10:02 PM
Bessie's Avatar
Bessie
Other than the heads, where can water get into the oil passages? The water is coming out of the oil passage that returns oil to the filter. I have the valley cover off and no sign of water. I have the oil pan off and no sign of water.
Old Jul 31, 2021 | 08:10 AM
hiball3985's Avatar
hiball3985
I'm a little con fused about your terminology? There is no return passage to the oil filter, oil only flows in one direction from the pump to the filter to the oil gallery and passages. Oil returns via drip into the pan. Are you saying the water is coming out of the oil filer mounting area? You see it with the filter off? In the heads if the water entered the oil passage for the rockers it would flow back down to the cam bearing area and then into the oil passage but that seem like it would be a small amount and most likely some would drip into the pan also so this seems confusing to diagnose.
Old Jul 31, 2021 | 04:30 PM
Bessie's Avatar
Bessie
Originally Posted by hiball3985
I'm a little confused about your terminology? There is no return passage to the oil filter, oil only flows in one direction from the pump to the filter to the oil gallery and passages. Oil returns via drip into the pan. Are you saying the water is coming out of the oil filer mounting area? You see it with the filter off? In the heads if the water entered the oil passage for the rockers it would flow back down to the cam bearing area and then into the oil passage but that seem like it would be a small amount and most likely some would drip into the pan also so this seems confusing to diagnose.
Thanks for clarifying the direction of oil flow. So yes, with the oil filter off, the water flows out of the oil filter mount area as fast as I pour it in. With the oil pan off and me under there and someone pouring water into the radiator, I see no water dripping down from the cam or anywhere else - nothing leaking on the outside. With the heads off and the water level just below the heads, all is fine with no water flow. Put the heads on (with gaskets properly installed front to front and one face side down, and torqued to 55, then 65 and then 75lbs.) and pour in more water, it flows out as fast as it goes in once it reaches the heads. Nothing is visible for me to see if its one head, or both heads that may be having a problem. The deck of the engine and the heads are pretty darn flat - this engine was rebuilt about 8 years ago, but never has run since then. I'm leaning toward one or both heads having a problem internally that allows the water to freely flow. What do you think?
Old Jul 31, 2021 | 09:57 PM
Bessie's Avatar
Bessie
Come on guys - I need you to weigh in on this one. Thanks for any thoughts you might have!
Old Aug 1, 2021 | 06:20 AM
hiball3985's Avatar
hiball3985
I've been working on Y blocks since 1965 and have never seen this problem before, and it has me baffled. I just can't visualize how water can get into the main oil gallery and back to the filter area in the amount you describe unless the block was severely cracked. But it doesn't do it with the heads off so that throws me. I'm sorry I can't be of any help at this point and can only sympathize and wish you luck.
Old Aug 1, 2021 | 05:18 PM
Bessie's Avatar
Bessie
Right? With the heads off I can see the water level just below the deck for the heads and no water is leaking out. I think I'll pull the heads again. I have not actually poured more water in with the heads off as I was thinking the heads are the problem - the water will likely just rise and overflow at the head decks. I'll post two videos - one with the heads on showing the water coming out at the oil filter, and another with the heads off and we'll see where the water goes.
With the heads off, I'll attempt to seal the water passages on each head, pour in water and see it it comes out some where it shouldn't. If it doesn't, and the block is holding water below the heads, I don't what the hell is going on..
Old Aug 2, 2021 | 08:05 AM
hiball3985's Avatar
hiball3985
I'll be watching with interest for sure. All my engine work has been on later 272,292 and I'm not that familiar with the 239 I know there are differences but I'm still stumped on how water can get to the filter area from the heads. It just doesn't seem possible.
Old Aug 2, 2021 | 03:54 PM
charliemccraney's Avatar
charliemccraney
You can't fill the block completely without the heads on. If you can figure a way to seal all of the passages so that the block can be filled completely, maybe it will show up then, without the heads on. Maybe tape the passages or a chunk of wood a s a makeshift "head" for testing. The only place I can thing that coolant could get into the oil galley is via the passage from the cam bearing.
Are the heads '55 or newer
Old Aug 2, 2021 | 04:07 PM
56panelford's Avatar
56panelford
I'd be of no help but what I was wondering was if a plug was removed and not reinstalled at the time it was rebuilt..one could have been removed during the cleaning process..
Old Aug 3, 2021 | 07:56 PM
Bessie's Avatar
Bessie
Where would that plug be?
Old Aug 3, 2021 | 07:59 PM
56panelford
I have no idea, it was just a suggestion of what may be the problem, I've never had one apart..Not sure if this helps, it's the Y-block oil passages ..
Old Aug 3, 2021 | 11:05 PM
Bessie's Avatar
Bessie
Trying to post a video... I'll figure this out.
Old Aug 4, 2021 | 11:46 AM
Bessie's Avatar
Bessie
That's the point I am at today - pull the heads and attempt to seal the water passages and add more water. I'll try this for the block as well as each head. Hoping to determine if the problem is in the block or one or both heads.
