quick question
Old Jul 29, 2021 | 01:42 PM
Listor's Avatar
Listor
quick question
am installing my fuel pressure gauge for the cst3 do i use the top port for post filter? at least that what i think i want!
Old Jul 29, 2021 | 01:44 PM
Walleye Hunter's Avatar
Walleye Hunter
The consensus is post filter since that is what your injectors will be getting.
Old Jul 29, 2021 | 01:48 PM
FordTruckNoob's Avatar
FordTruckNoob
Bottom one by the fuel outlet ports on the bowl.
Old Jul 29, 2021 | 02:22 PM
Listor's Avatar
Listor
well I have it installed in the top one and am getting nothing? Seems odd
Old Jul 29, 2021 | 02:29 PM
bigb56's Avatar
bigb56
I thought the bottom one was post filter? That's where mine is.
Old Jul 29, 2021 | 02:31 PM
FordTruckNoob
Really? You should still see pre-filter pressure. I’m assuming you have the truck running as you are trying to read fuel pressure.
Old Jul 29, 2021 | 02:56 PM
Walleye Hunter
Bottom one is post filter and I misread Listor's first post. I thought he said, "Top one or post filter?", didn't register that 'f' in there. No reading? Not to sound stupid but, did you turn the key on? Kind of like, "Is the toaster plugged in?"
Old Jul 29, 2021 | 04:06 PM
Listor's Avatar
Listor
lol yea I had the truck on and running I was needing to reconfigure the eas to recognize the sensor
Old Jul 30, 2021 | 08:49 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
If the pump is pressurizing the system and you are not receiving a signal from the sensor that the CTS3 can translate into PSI, there is a wiring fault, sensor fault or fault between the translation of the CTS3 and the sensor. For example, ISSPRO gauges have microprocessors in them to "translate" what the sensor is relaying as the sensor is just a transmitter of certain data points along the specific scale.
I snagged this image from Guzzle and inserted a red arrow to the port you DO want to install the sensor in. That is the post-filter port and what is more important than the pre-filter port.
Old Jul 30, 2021 | 11:48 AM
Listor's Avatar
Listor
I figured out I needed to reconfigure the sensor , I had pulled the sensor from the aih where I was pulling boost from , no big deal I need to pull the fuel bowl to install the 90 but I think I need another straight piece so the 90 will turn , or maybe I can pull the fuel bowl drain allowing it to clear?
Old Jul 30, 2021 | 12:14 PM
Sous's Avatar
Sous
FTE Emeritus
SSJ has had good luck with mounting the sensor horizontally on many trucks, I and many others have not and had to use a vertical method. I ended up using a 90° adapter from Diesel-O-Rings. I did have to trim the yellow lever a bit, but I have found no hinderance to opening the valve in times I have needed to.
Old Jul 30, 2021 | 12:15 PM
RacinJasonWV's Avatar
RacinJasonWV
FWIW I didn’t use the 90° when installing the Autometer pressure sensor (yes, bottom port). Used a simple straight ORB-NPT adapter. This wouldn’t fit if also using a snubber though.
Old Jul 30, 2021 | 01:18 PM
FordTruckNoob
I mount mine horizontally too.
Old Jul 30, 2021 | 01:54 PM
Sous's Avatar
Sous
FTE Emeritus
Looks like it really depends on the sensor model/manufacturer, adapters and the HPOP lines in relation to the the sensor.
Really, there is no wrong way to install the sensor as long as it is clear of abrasion concerns.
A bit more information here: https://www.ford-trucks.com/forums/1...t-install.html
Old Jul 30, 2021 | 06:14 PM
RacinJasonWV
Sous, I just noticed you posted while I was typing my earlier reply about the straight versus 90. We said similar things but were completely unrelated to each other’s comments. Just wanted to clear the air in case it sounded like I was trying to argue a point. Didn’t even know you’d mentioned it.
