Diesel, DPF Not Accumulating
Old Jul 29, 2021 | 12:00 AM
Cappsa's Avatar
Cappsa
I am on the last leg of a road trip towing our travel trailer. I just turned over 10,000 miles on the truck. I’ve noticed a couple of things the past couple of days, my fuel economy has dropped about 1.5 to 2 mpg. Secondly, I’ve been watching the DPF and noticed that it has not gone up from 0% these past two days, about 450 miles. I hooked up my ODB2 scanner no codes.
What should I be looking at or am I worrying for no reason?
Old Jul 29, 2021 | 02:46 AM
jsukey's Avatar
jsukey
It's because your truck is doing passive regeneration due to the exhaust being hot enough to burn off the soot. That is normal when towing heavy loads. Just FYI, your truck will automatically go into a regen every 500 miles or so, regardless of where you're soot level % is at.
Old Jul 29, 2021 | 05:26 AM
senix's Avatar
senix
you are towing, my personal record is no regens in 2600 miles. Fuel economy, you have a sail behind you and the terrain and maybe wind does not help.
DEF usage goes up though.
Old Jul 29, 2021 | 05:45 AM
cpobst's Avatar
cpobst
This. Unless you turn off auto regen. I've gone 1200ish miles without a regen before.
Old Jul 29, 2021 | 05:49 AM
cpro24's Avatar
cpro24
yES YOUR WORRYING FOR NO REASON...
Your truck is smart enough to do what needs to be done ..and when theres a problem u will know about it with an endless warnings and check engine lights etc
Old Jul 29, 2021 | 08:34 AM
Sport45's Avatar
Sport45
The mpg loss may be due to different grade fuels sold around the country. Cetane ratings aren’t the same everywhere
ForBruce
Jan 10, 2021 05:50 AM
Mustang251
May 3, 2012 09:13 AM
ranger88stx
Delaware Chapter
Feb 20, 2007 07:04 AM
truckchop
Feb 13, 2007 06:56 AM
NY Signman
Dec 20, 2005 10:52 PM
